Max Vol Rect Solid Cut from Sphere: Find Dim & Vol
The discussion focuses on determining the dimensions and volume of a rectangular solid cut from a sphere with radius r. The function defined for the volume is F(l,b,h) = lbh, where l, b, and h represent the length, breadth, and height of the solid. The key constraint is that all corners of the solid must touch the sphere's surface, which is defined by the equation x² + y² + z² = r². Participants emphasize the importance of simplifying the equations by selecting appropriate coordinates for the solid's vertices.
  • Understanding of geometric constraints in three-dimensional space
  • Familiarity with the equation of a sphere in Cartesian coordinates
  • Knowledge of optimization techniques in calculus
  • Ability to work with multivariable functions
  • Study the optimization of multivariable functions using Lagrange multipliers
  • Learn about geometric properties of solids inscribed in spheres
  • Explore the implications of coordinate transformations in geometric problems
  • Investigate practical applications of volume maximization in engineering design
Mathematicians, engineers, and students in geometry or optimization fields who are interested in maximizing volumes of solids within given constraints.
paulojomaje
A rectangular solid of maximum volume is to be cut from a solid sphere of radius r. Determine the dimension of the solid so formed and its volume?
I have defined my function F(l,b,h) as lbh, but i don't know how to define my constraint condition from my question
The constraint - I don't know what stops you seeing this - is that all the corners have to be at the surface of the sphere. Do you know what the equation for a sphere of radius r is (meaning the relation between r and co-ordinates x, y, z holding at all points on the surface)?
Then before you start, think how many independent co-ordinates of the touching points are you going to need? There are 8 points where your solid will touch the sphere surface but you sure need to specify a lot less than that if it is going to be a 'rectangular solid'.
A tip: make equations as simple as possible by choosing simple co-ordinates for points. All points on the sphere are equal as starting points. So you can make your first point (r, 0, 0) for instance.
So now tell us about other points.
  • · Replies 16 ·
