Law of conservation of momentum
The discussion revolves around a problem related to the law of conservation of momentum, specifically involving the force exerted by wind on a person during a storm. The scenario includes parameters such as wind speed, the rate at which air strikes a person, and the dimensions of the person.
  • Participants explore the interpretation of the problem, particularly questioning what is meant by "brought to rest." There is discussion about the momentum change of the air and its relation to the force on the person. Some participants attempt calculations based on the given parameters, while others express uncertainty about their methods.
Participants are actively engaging with the problem, with some providing calculations and others confirming the reasoning behind the momentum change. There is a mix of interpretations being explored, particularly around the concepts of impulse and momentum.
There is a noted ambiguity regarding the definitions and assumptions in the problem, particularly about what comes to rest and the nature of the force transfer during impulse. The problem is framed within a homework context, which may impose specific constraints on the discussion.
FarazAli
I can't seem to figure out what the damn question is asking :D. Can anyone explain what the question is asking?
During a chicago storm, winds can whip horizontaly at speeds of 100 km/h. If the air strikes a person at the rate of 40kg/s per square meter and is brought to rest, calculate the force of the wind on a person. Assume the person's area to be 1.50m high and 0.50m wide. Compare to the typical maximum force of friction (μ = 1.0) between the person and the ground, if the person has a mass of 70kg.
What comes to rest here? is it the air or the person?
Also on a side note, can anyone explain whether the transfer of force during impulse instantaneous or not?
The air is. Consider the person standing still. The rate of change in momentum of the air is equal and opposite to the force on the person.
Ok this is how I solved the problem. I doubt it's right.
I see that the force is in units of [tex]kg/sm^2[/tex] and I have an area in square meters, so I multiplied the two of them to get this
[tex](\frac{40 kg}{m^2s})(1.0m)(0.5m) = 30 \frac{kg}{s}[/tex]
I plugged that into [tex]\Delta{p} = F\Delta{t} = (\frac{m\Delta{v}}{\Delta{t}} \times \Delta{t}) = m\Delta{v}[/tex] and got [tex]\frac{30kg}{s} \times \frac{27.8m}{s} = 8.3\times10^2N[/tex]
looks good to me. :-D
That's correct. In 1 second 30 kg of air having a speed of 27.8 m/s comes to rest.
So the change in momentum (which equals the force) is [itex]30 \cdot 27.8 = 8.3 \cdot 10^2N[/itex]
  • · Replies 24 ·
