Jet Engine Question Homework: Find Thrust w/ 100% Efficiency
A jet engine differs from a rocket engine as it utilizes atmospheric air for combustion instead of carrying its own oxidizer. In the given scenario, the jet engine operates at 210 m/s, intake air at 74.2 kg/s, and fuel at 3.20 kg/s, ejecting combustion products at 502 m/s. To calculate thrust with 100% efficiency, the formula must account for the mass flow of air and the change in velocity, factoring in ambient pressure differences. The negligible contribution of burnt fuel gas in jet engines is highlighted, emphasizing the dominance of cold air mass in thrust calculations. Understanding these principles is crucial for accurately determining jet engine thrust.
didinyc
The major difference between a jet engine and a rocket engine is that a rocket carries its
own oxidizer, usually in the form of liquid oxygen (LOX). A jet takes in air from the
atmosphere as it moves, uses it to burn the fuel, and then ejects all the gases out the
back.
At a certain instant, a jet engine is moving 210 m/s. The engine takes in air at a rate of 74.2
kg/s, combines it with 3.20 kg/s of fuel, and ejects the products of combustion at constant
speed 502 m/s relative to the jet. Assuming 100% efficiency: find the numerical value of the
thrust of this engine.
HINT: For a rocket engine: Thrust rel= v(relative)* (dm/dt)
How must this expression be modified for a jet
engine?
I tried to read the book to solve it but cannot start anything if i get an idea of how to start, I will try to solve it! Thanks for the help!
Thrust is a force and Force = mass x acceleration. The amount of burnt fuel gas in the air flowing through an engine is so small as to be negligible and is not included in calculations for thrust. Thus it is the mass of cold air in (which must come out) times the increase in velocity, viz: Thrust = mass(air) times (V-exhaust minus V free stream)+(Pressure of ambient air minus presure exhaust air) times area of exhaust nozzle
The overall point relating to your question is that the amount of burnt fuel gas in a straight rocket exhaust is considerable compared to that in an air breathing jet engine.
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
