Solving Division: Understanding Zero as a Placeholder
  • Thread starter Thread starter roger
    Division
The discussion revolves around understanding the long division process, specifically the division of 3 by 4. The original poster is confused about the placement of zeros in the long division setup and the transition from dividing 3 to dividing 30.
  • Exploratory, Assumption checking
  • The original poster attempts to clarify why a zero is not placed on top when dividing 4 into 2 after initially dividing 4 into 3. Some participants question the reasoning behind the placement of zeros in long division and the implications of bringing down numbers.
Participants are exploring different interpretations of the long division process. Some provide guidance on the standard approach to placing zeros and decimals, while others express confusion about the original poster's reasoning. There is no clear consensus on the best method, but various perspectives are being shared.
There is a mention of differing methods of long division between countries, which may contribute to the confusion. The original poster is also grappling with the implications of placing zeros in relation to the decimal point.
roger
HI
please can someone help me with this quick question on division :
If I have to do 3 divided by 4
____
4 |3
4 doesn't go into 3 so I put a zero on top .
When it gets to 4 into 2(from 30-4x7), it doesn't go, so why don't I put a zero on top but instead put a zero beside the 2 to make it 20 ?
thankyou
roger
I have no idea what you're doing.
If you're doing 3 divided by 4 using long division:
http://home.comcast.net/~iberiaforums/division.GIF
roger:
Do you want to perform 3:4 or 4:3?
arildno said:
roger:
DEAR ARILDNO,
I AM TRYING TO DO 3 DIVIDED BY 4 LONG DIVISION
BUT WHY DONT I PUT A ZERO ON TOP FOR 4 INTO 2 ?
ROGER
roger said:
DEAR ARILDNO,
ROGER
Look at my link.
You never put a 0 on top.
What you do in the first step is put a decimal point on top.
dav2008 said:
Look at my link.
just looking at the link...
when you do 7x4 =28
and then 30 minus 28 = 2.
from here
4 doesn't go into 2 so why don't I put a zero on top ?
This is what I want to know ...
thanx
roger
Now, since to write down the long-division algorithm is a bit difficult (and besides, we do it differently in Norway from the US), I will show you the RATIONALE behind the long division technique instead; long division is simply a condensed version of what I'll present.
1. What is meant by "division" in this case?
Ordinarily, "division" is meant to be that process that rewrites a number, given as a FRACTION, into the equivalent DECIMAL REPRESENTATION of that number (which, as it happens, is a particular TYPE of fractional representation).
2. Let's look at the number given by fraction 3/4
We want to write 3/4 in its decimal representation, that is to find digits [tex]a_{i}[/tex] between 0 and 9, so that we have:
[tex]\frac{3}{4}=0.a_{1}a_{2}a_{3}...[/tex]
Where the notation [tex]0.a_{1}a_{2}a_{3}...[/tex] MEANS:
[tex]0.a_{1}a_{2}a_{3}...\equiv\frac{a_{1}}{10}+\frac{a_{2}}{100}+\frac{a_{3}}{1000}++[/tex]
3. Let's start!
a) We note that 3<4, so our first step is to multiply 3/4 with an appropriate representation of the number "1":
[tex]\frac{3}{4}=1*\frac{3}{4}=\frac{10}{10}*\frac{3}{4}=\frac{1}{10}*(\frac{30}{4})[/tex]
Henceforth, we will work with the expression included in the parenthesis.
b)
We note that 30>4, and the greatest multiple of 4 which is less than 30, is 4*7=28.
Hence, we write 30=4*7+2
We therefore have the equality:
[tex]\frac{30}{4}=\frac{4*7+2}{4}[/tex]
c)We now use the fact that we can split up a sum in the numerator into a sum of fractions:
[tex]\frac{4*7+2}{4}=\frac{4*7}{4}+\frac{2}{4}=7+\frac{2}{4}[/tex]
The last step follows since 4 is a common factor in both the numerator and denominator in the first fraction.
d) Hence we have shown:
[tex]\frac{3}{4}=\frac{1}{10}*(7+\frac{2}{4})[/tex]
This can be rewritten as:
[tex]\frac{3}{4}=\frac{7}{10}+\frac{1}{10}(\frac{2}{4})=0.7+\frac{1}{10}(\frac{2}{4})[/tex]
e) We will now work with the parenthesized 2/4.
Since 2<4, we multiply 2/4 by an appropriate version of 1:
[tex]\frac{2}{4}=1*\frac{2}{4}=\frac{10}{10}*\frac{2}{4}=\frac{1}{10}*(\frac{20}{4})[/tex]
f) We note that 20=5*4, so we have:
[tex]\frac{2}{4}=\frac{1}{10}*(\frac{5*4}{4})=\frac{1}{10}*(5)=\frac{5}{10}[/tex]
g) We now look back at the equation in d):
[tex]\frac{3}{4}=0.7+\frac{1}{10}(\frac{2}{4})[/tex]
With the result from f), we have:
[tex]\frac{3}{4}=0.7+\frac{1}{10}(\frac{5}{10})=0.7+\frac{5}{100}=0.7+0.05=0.75[/tex]
And that's our result..
I'm confused about your question "WHY DONT I PUT A ZERO ON TOP FOR 4 INTO 2 ?" because I certainly WOULD put a 0 on top!
4 goes into 3 0 times so I would put a 0 before the decimal point and continue:
__0.
4) 3.0
Now, 4 divides into 30 (ignore the decimal point now- we've already taken care of it) 7 times: 4*7= 28
__0.7
4) 3.00
_28_
and now 4 divides into 20 5 times, evenly
__0.75_
4) 3.000
_2 8__
Of course, you don't HAVE to put the "0 on top" because 0, after all, means NOTHING! 0.75 is the same as .75 although I think you will find that "0.75" is preferred in "formal" writing.
__0.
4) 3.0
__0.7
4) 3.00
_28_
this is where my concern was...
I thought it was 4 divides into 2 NOT 20.
So is that to say because the decimal point has been put down, it is really the calculation of 30 divided by 4 ?
Because if it had been 2 instead of 20, my question was if 4 does not go into 2, then why do I not put a zero on top to indicate this .And then I would have brought down a zero to make it 20 and proceed from there...
If I ever have to bring down a zero, where does it come from ? __0.75_
4) 3.000
_2 8__
"Because if it had been 2 instead of 20, my question was if 4 does not go into 2, then why do I not put a zero on top to indicate this "
And my answer was you certainly can "put a zero on top to indicate this."
You don't HAVE to since ".75" is commonly understood as "0.75" although, in my opinion, 0.75 is better.
It still doesn't answer my query because if I had done it my way, I would have got an answer of 0.705
This is wrong it should be 0.75 but I'm referring to the zero after the 7 not before the decimal point ?
Please help me to understand this
Roger
Roger
Ok, I don't understand why you WANT to put the zero on the top?
Lets walk through an easy example the way you want to do it and the correct way:
116/4
___2
4)116
2*4=8
11-8=3
Now 3/4=0
___20
4)116
bring down the 6
36/4=9
___209
4)116
Does that look like the correct answer? No. The reason you don't put the 0 on the top is that you don't redivide the remainder from one step to the next.
Good luck.
Roger
Your question is like asking "why don't you add a zero when you divide 30/5 and get 6, not 60"
You just don't. That's how it's done.
  • · Replies 16 ·
  • · Replies 63 ·
  • · Replies 17 ·
