Prove System of Forces Equivalent for Triangle Vectors
  • Thread starter Thread starter batballbat
    Triangle Vectors
The problem involves proving the equivalence of two systems of forces represented by vectors in a triangle. Specifically, it asks to show that the forces connecting a point to the vertices of a triangle are equivalent to those connecting the same point to the midpoints of the triangle's sides.
  • Exploratory, Conceptual clarification
  • One participant attempts to find the resultant of the forces connecting the point to the vertices and midpoints, suggesting they should yield the same resultant. Another participant questions whether the problem implies that the resultant of the three vectors is the same.
The discussion is ongoing, with participants exploring the implications of the problem and clarifying the nature of the forces involved. Some guidance has been offered regarding the use of vectors, but no consensus has been reached on the approach or interpretation of the problem.
Participants are working within the constraints of the problem statement and are attempting to clarify the relationships between the vectors without additional information or assumptions.
batballbat
Show that the system of forces represented by the lines joining any point to the angular points of a triangle is equivalent to the system represented by straight lines drawn from the same point to the middle points of the sides of the triangle
i tried to find the resultant of the three forces which joint the point to the angular point and the three forces which join the point to the respective midpoints. i must get the same resultant i guess. but i didnt.
hi batballbat! :smile:
just use vectors a b and c :wink:
Does the question mean that the resultant of the pair of three vectors is the same?
yes :smile:
