How Does Rotating Forces Through Equal Angles Affect Their Resultant?
The problem involves two forces acting at distinct points on a body and examines how rotating these forces through equal angles affects their resultant. The subject area pertains to mechanics and vector addition.
  • Participants discuss the location of the resultant force and the implications of rotating forces. Some suggest analyzing specific cases to identify the resultant's behavior, while others question the significance of the point of application of the forces.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have provided hints and guidance on how to approach the problem, while others express confusion about the terminology and concepts being used.
There are indications of missing information regarding the specific points of application and the nature of the forces involved. Participants are also navigating the constraints of homework rules that limit direct solutions.
batballbat
Two given forces act at two given points of a body; if they are turned round those points in the same direction through any two equal angles, show that their resultant will always pass through a fixed point.
i tried but could not make any progress with the problem
hi batballbat! :wink:
the first thing to do is to find where that point is …
so try the two simplest cases, one in which the first force points along AB, and one in which the second force points along AB …
what do you get? :smile:
batballbat said:
if two forces act on different points of a body then at which point does the resultant act?
hint: add the two forces, then subtract the resultant …
that must be zero, and in particular, its moment about any point must be zero :wink:
i didnt get u
if you have a force F along the line AP, and another force F along the line BQ,
and if the resultant of F and G is H,
the the resultant of F G and -H must be zero,
so in particular the moment of F + G - H about any point must be zero …
so what point must H go through?​
i have the problem of adding two vectors not acting at the same point. can u give me a general solution?
the point of application of the force does not matter,
only the line of application of the force matters …
if a force is acting at a point A, it's the same as if it was acting at any other point on the line through A in the direction of the force
ok so the resultant acts along AD
what's D ?? there isn't a D ! :confused:
go back to my previous question …
is it one of the two given points on the body?
just give me an answer if u are not allowed to give a solution
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 25 ·
9K
