How Are Tensor Indices Ordered in Calculations?
This discussion focuses on the manipulation and ordering of tensor indices in calculations. It establishes that a consistent ordering of indices is crucial for operations like raising and lowering indices, with the first convention being preferred. The order of indices in a tensor product is generally determined by placing the indices of the first tensor followed by those of the second tensor, although flexibility exists in notation. Additionally, dummy indices do not appear in the final list of indices, and the placement of the metric tensor does not affect the outcome as long as the notation remains clear.
  • Understanding of tensor notation and operations
  • Familiarity with tensor products and their properties
  • Knowledge of raising and lowering indices using metric tensors
  • Basic grasp of dummy indices in tensor calculations
  • Study the conventions of tensor notation in "Introduction to Tensor Analysis" by C. Truesdell
  • Learn about tensor products and index permutation in "Tensor Calculus for Engineers and Physicists"
  • Explore the implications of dummy indices in tensor operations
  • Review the role of metric tensors in general relativity and their application in raising and lowering indices
Mathematicians, physicists, and engineers involved in advanced calculations involving tensors, particularly those working in fields such as general relativity or continuum mechanics.
Andy_X
I would welcome advice on the practical issues of manipulating tensor indices, in particular how to determine the order of indices during calculations. Some of the following questions are probably simplistic but I have been unable so far to find a consistent answer.
1) Some texts use a unique order for the complete set of indices on a tensor, leaving spaces in the subscript list where superscripts appear and vice versa. Others have superscripts and subscripts above one another. What is the difference and when is it important to have an ordering for the combined set?
2) How is the order of indices determined for a tensor product? E.g. if W=ST are the indices of W formed from the indices of S followed by the indices of T and is this also the case for mixed tensors?
3) How is the answer to 2) affected if the product of two tensors also involves a dummy index? i.e. does the dummy index just disappear from the combined list of subscripts and superscripts?
4) in raising (or lowering) indices using a metric tensor (or the inverse metric) some texts always put the metric to the left of the tensor being changed (and the inverse to the right) while other texts don’t make this distinction. Which is correct? Also where does the raised (lowered) index fit into the pre-existing list of superscripts (subscripts)?
Any help greatly appreciated
It is best to stick to the first convention, where ALL indices (up or down) are put in a definite order. The reason is because you might want to raise or lower indices. There are a few occasions where it's ok to forget about ordering, such as [itex]\delta^a_b[/itex].
Really, index notation allows you to mix up the order a bit. Strictly speaking, W should have the S indices first, and the T indices second, but nothing prevents you from writing
[tex]W_{abcd} = S_{ac}T_{db}[/tex].
The notation explicitly tells you what the new ordering of indices is. Strictly speaking, this is not merely [itex]W = S \otimes T[/itex], but it is [itex]W = \mathcal{P} (S \otimes T)[/itex], where [itex]\mathcal{P}[/itex] is a map that permutes the indices in a specific way.
Yes. For example, one can write
[tex]W_{abcd} = S_a{}^e{}_c T_{dbe}[/tex].
It doesn't matter where you put the metric when you write out the indices explicitly. The order is simply whatever you write down. For example, you might write
[tex]W_{abcd} = g_{ce} S_a{}^e{} T_{db}[/tex].
It is important to give a definition of the symbol [itex]W_{abcd}[/itex] and remain consistent, but it doesn't matter exactly what order you write all the factors, because the index notation tells you exactly which parts slots are contracted, and which slots get mapped to where.
  • · Replies 16 ·
  • · Replies 19 ·
