Problems like four-colour theorem
  • Context: Graduate
  • Thread starter Thread starter jobsism
    Theorem
The discussion revolves around problems related to the four-color theorem and similar challenges in topology and graph theory. Participants share various mathematical problems that are intriguing yet accessible, exploring concepts in geometry and coloring theories.
  • One participant expresses interest in finding problems similar to the four-color theorem, specifically in topology.
  • Another suggests exploring graph theory books for various problems, including the isoperimetric problem and the Kakeya needle problem, noting their accessibility but potential complexity in solutions.
  • A mention of the seven-color theorem on the surface of a torus is introduced as an additional problem to consider.
  • Participants discuss the use of more than four colors in maps, with one suggesting that five or more colors may be necessary for clarity in specific contexts, such as color-coding regions based on earthquake risk.
  • There is a debate about the necessity of more than four colors for map coloring, with some participants speculating on aesthetic reasons or practical needs due to non-connected regions.
  • One participant points out that the four-color theorem assumes connected regions, which does not hold for some real-world maps, complicating the application of the theorem.
  • Another participant highlights the need for a color reserved for water on maps, further complicating the coloring process.
  • Lastly, a participant mentions a game related to the topic, suggesting it might be of interest to others.
Participants present multiple competing views regarding the necessity of more than four colors in map coloring, particularly in relation to the four-color theorem and real-world applications. The discussion remains unresolved with differing opinions on the reasons for using additional colors.
Some assumptions about the connectedness of regions and the implications for coloring maps are discussed, but no consensus is reached on the necessity of more than four colors in all cases.
jobsism
I recently came across the four-colour theorem, and found it so interesting that I spent hours trying to find a counterexample(even though I knew there couldn't be one!)...now I'm so obsessed with trying out problems like these...can anyone suggest me problems like these in topology, which are simple to understand and yet so enticing??
Get a book in graph theory, you should find many problems like this in such a books...
Some other nice problems:
- The isoperimetric problem: determine a plane figure of the largest possible area whose boundary has a specific length.
- Kakeya needle problem: find the smallest convex set in the plane in which you can reverse a needle (see: http://www.math.hmc.edu/funfacts/ffiles/20005.2-3.shtml )
Other nice problems are in http://www.math.hmc.edu/cgi-bin/funfacts/main.cgi?Subject=00&Level=0&Keyword= These problems are all very easy to understand, but the solution can be extremely difficult...
On the surface of a torus, you have a seven-color theorem. There's one you can play with.
And speaking of the four-color theorem, most world maps actually use five colors. Aside from just being easier (you don't have to put as much thought as to what color goes where), why would they need to do this?
Thank you guys for the suggestions! I'm going to try out these problems...as for the isoperimetric problem, isn't circle the answer? I read somewhere that for a specific perimeter, the circle possesses the largest area...
And Ben, I think more than 4 colours are used in maps because 4 aren't enough for specific details...like maybe in colour-coding regions prone to earthquakes, I think upto 7 colours are used for specifying which regions are more prone than others by a range of values...for each range, a colour is used...i may be wrong too...;D
Ah, yes, but how to prove such a thing. The proof is not evident...
Oh..I see...perhaps it goes the same way as the 4 colour problem...taking all possible sets of curves and eliminating everything (forgive me if I'm wrong..I dint actually view the proof), leaving the circle alone...
No, I don't mean fancy features like color-coded earthquake regions. I mean just the colors that are used to fill in each country. Why would mapmakers need more than 4?
In that case, I've no idea...maybe its to increase the beauty or sth...I mean 10 colors would be more colorful than 4, ryt?;D
When I was a kid all the commonwealth countries were pink. So that restricts your choices for the other countries who's colors don't usually matter but can't be pink. Probably also helps to clarify that two nearby countries with small ones sandwiched between them aren't actually the same thing.
No, neither of those reasons.
The four-color theorem assumes that each region to be colored is connected (i.e., that each region is all in one piece). However, on a real map of the world, some regions are NOT connected. That is, some countries actually have two separate pieces with other countries in-between (usually the result of wars). Those two pieces need to be colored the same color, which is sometimes impossible with only four colors.
Never mind countries; what about water? You need to reserve a color (I recommend blue) for water, so you can easily distinguish large lakes from countries. If you do that, you still need four more colors unless it's a very simple map.
jobsism would enjoy the game of "Y" or mudcrack Y and also poly-Y.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 37 ·
  • · Replies 25 ·
  • · Replies 106 ·
16K
