Quick Question about the mag field of a solenoid
  • Thread starter Thread starter JamesL
    Field Solenoid
The discussion centers on the behavior of a light bulb connected in series with a solenoid when an iron rod is rapidly inserted and removed. The consensus is that the correct answer is option #7: the bulb dims as the rod is thrust into the solenoid and brightens as it is removed. This occurs because the iron rod, acting as a conductor, temporarily diverts some of the magnetic force from the solenoid, causing a decrease in current and dimming the bulb. Upon removal of the rod, the magnetic field decreases, allowing the current to return to its original path, resulting in the bulb brightening.
  • Understanding of electromagnetic induction principles
  • Familiarity with solenoid operation and magnetic fields
  • Basic knowledge of electrical circuits and series connections
  • Concept of magnetic flux and its effect on current flow
  • Study Faraday's Law of Electromagnetic Induction
  • Learn about the behavior of inductors in electrical circuits
  • Explore the effects of magnetic materials on magnetic fields
  • Investigate the relationship between magnetic fields and current in solenoids
Students of physics, electrical engineers, and educators looking to deepen their understanding of electromagnetic principles and circuit behavior involving solenoids and magnetic fields.
JamesL
A light bulb and a solenoid are connected in series to a battery. An iron rod is thrust rapidly into the solenoid and later rapidly removed. The bulb:
1)No change in or out
2)No change in, brightens out
3)Dims in, Dims out
4)Brightens in, dims out
5)Brightens in, brightens out
6)remains brighter the entire time
7)Dims in, Brightens out
8)Brightens in, no change out
9)Dims in, no change out
10)no change in, dims out
Im leanin towards #7, dims as the rod is thrust into the solenoid, and brightens as it is removed. since the iron rod is a conductor, it would draw some of the mag force away from the solenoid (and therefore the battery) thus making it dimmer... and then when it is removed, the bulb would brighten back to its original state...
is this reasoning correct? any help?
solved. nevermind
Yes, your reasoning is correct. As the iron rod is rapidly thrust into the solenoid, it will create a temporary increase in the magnetic field within the solenoid. This will cause the bulb to dim slightly as some of the current is diverted to the rod. When the rod is rapidly removed, the magnetic field will decrease and the current will return to its original path, causing the bulb to brighten again. So, the correct answer is #7, dims in and brightens out.
12K
15K
