| New Reply |
Monochromatic light |
Share Thread | Thread Tools |
| Apr29-11, 01:40 PM | #1 |
Monochromatic light
I'm doing work with a spectrometer and Hydrogen and Helium gas discharge tubes. Right now I'm studying the Balmer series for Hydrogen emission.
Anyway, I'm trying to see what the "real" definition of monochromatic light is. Some references state it's light of one frequency while other references state that it's light of one wavelength? Which is it? If I look at a Hydrogen gas discharge tub, it looks "monochromatic" but when viewed through a spectrometer / diffraction grating, spectral lines at multiple wavelengths can be seen. How is monochromatic light made? Any examples of it in the physical world aside from in a lab? |
| Apr29-11, 01:46 PM | #2 |
'Mono' = one; 'chroma' = color.
How many wavelengths do you have for a single frequency of light? How does something 'look' monochromatic? If it has lines at multiple wavelengths, is it monochromatic? Real world example: LEDs and Lasers (although neither---especially lasers---are perfectly monochromatic, they have some spread/uncertainty). |
| Apr29-11, 02:40 PM | #3 |
Monochromatic wave = single frequency.
In the nature there is no monochromatic waves because emission of a light occurs at a defined fraction of time. |
| Apr29-11, 05:11 PM | #4 |
Monochromatic lightNormally monochromatic light is made by using lasers, LED's, or certain types of filtering techniques depending on the frequency you need and how close to the exact frequency you need most of the light. I don't believe there are any examples of pure monochromatic light in nature. But I'm not sure. |
| Apr30-11, 01:48 PM | #5 |
| Apr30-11, 07:34 PM | #6 |
A true monochromatic wave only exists mathematically, and is usually represented as a simple sine or cosine function.
In the lab, you can make nearly monochromatic beams with gas discharges, photodiodes, or various kinds of lasers, and add filters as needed. In each case, there is inherently a spread in the range of wavelength. The spread can be somewhat tuned, but cannot be absolutely zero. Examples of natural limitations are impurities of emitting material, non-zero temperature, and ultimately the uncertanty principle. |
| Apr30-11, 09:13 PM | #7 |
Recognitions:
| May1-11, 03:02 AM | #8 |
Light that is detected by the light sensitive cells in the retina is processed. Our retinas do extract information, so we're sensitve to hue and so on, but the incoming light is not resolved in constituent frequencies as happens with a diffraction grating. For most purposes the light of a Sodium lamp is effectively monochromatic. But a sufficiently high spec diffraction grating shows that Sodium lamp light is two spectral lines that are very close together. When a light source is referred to as 'monochromatic' what is meant is that the light is sufficiently monochromatic for the intended purpose. |
| May1-11, 06:55 AM | #9 |
I know that the uncertainty principal states that you cannot know the exact momentum of a particle because observing it actually changes its trajectory. How does that factor into the fact that light can't be 100% monochromatic? |
| May1-11, 07:10 AM | #10 |
Otherwise, pass a beam in a prism. A polychromatic (such as white) beam will spread in the rainbow colors. Well, a seemingly monochromatic beam will also spread, ever so slightly. 2. p = hf (a photon's momentum and wavelength are related by this very simple relation, h is a constant (Planck's)). This is correct but both p and f always have an uncertainty, or a "spread", or a linewidth, or an error (all practically synonyms in this context). |
| May1-11, 08:55 AM | #11 |
Mentor
Truly monochromatic light takes an eternity to determine that it is so. So there is no physical source that is perfectly monochromatic. However, many sources are very, very close, and as such it is a useful abstraction. Just like the stretchless rope. |
| New Reply |
| Tags |
| balmer series, monochromatic light |
| Thread Tools | |
Similar Threads for: Monochromatic light
| Monochromatic and Coherent light | General Physics | 12 | ||
| monochromatic light and reflection | Introductory Physics Homework | 6 | ||
| Is Monochromatic Light Real? | Quantum Physics | 9 | ||
| Monochromatic Light Through Two Microscope Slides | Introductory Physics Homework | 3 | ||
| Monochromatic Light | Introductory Physics Homework | 1 | ||
