Def. of (mod2) reduction of w in H_2(M,Z)
  • Context: Graduate
  • Thread starter Thread starter Bacle
    Reduction
The discussion centers on the definition and implications of the "mod2 reduction of a homology class," particularly in the context of characteristic classes in 4-manifolds. Participants explore the relationship between homology classes, Poincaré duality, and the Stiefel-Whitney class.
  • Some participants propose that the mod2 reduction involves evaluating each coefficient term of a Z-chain mod2.
  • Others explain that a Z-chain can be transformed into a Z/2 chain through coefficient projection, leading to a long exact sequence of homology groups.
  • A participant suggests that a characteristic surface is Poincaré dual to the Stiefel-Whitney 2-class, raising questions about the conditions under which this duality holds.
  • There is a discussion about the implications of the Universal Coefficient Theorem, particularly regarding the relationship between torsion and isomorphism between chain groups.
  • Another participant mentions that Poincaré duality may hold mod2 regardless of the orientability of the manifold, suggesting that the tangent bundle's properties influence this relationship.
  • Concerns are raised about the clarity of statements regarding duality and the conditions under which it applies, particularly in relation to triangulation and simplices.
Participants express various viewpoints on the definitions and implications of mod2 reduction and Poincaré duality, indicating that multiple competing views remain and the discussion is unresolved.
Participants note that the discussion involves complex relationships between homology, cohomology, and duality, with references to specific mathematical theorems and sequences that may require further clarification or assumptions.
Bacle
Hi, All:
Just curious as to the definition of the "mod2 reduction of a homology class".
The context is that an element w in H<sub>2</sub>(M<sup>4</sup>,Z) is called
characteristic if "its mod reduction [w]<sub>2</sub> is Poincare-dual to the
Stiefel-Whitney class w<sub>2</sub> in H<sup>2</sup>(M<sup>4</sup>,Z),
where M<sup>4</sup> is a 4-manifold. Does the reduction just mean that we
start with a Z-chain , and then each coefficient term in the chain is evaluated
mod2?
Thanks.
Yes. If M is an R-module and N a submodule, then it is easy to see that for any topological space X, the morphism of graded R-modules
[tex]C_*(X;M)\rightarrow C_*(X;M/N): xc\mapsto [x]c[/tex]
is a chain morphism. So it passes to homology and the resulting morphism
[tex]H_*(X;M)\rightarrow H_*(X;M/N): x[z]\mapsto [x][z][/tex]
is called "mod N reduction of the homology".
Bacle said:
Hi, All:
mod2?
Thanks.
A Z chain becomes a Z/2 chain by coefficient projection , Z -> Z/2.
The exact sequence of coefficients 0 -> Z -> Z -> Z/2 -> 0 gives a long exact sequence of homology groups. I think the connecting homomorphism is called the Bockstein homomorphism.
Thanks, both.
I guess then that a characteristic surface would then be Poincare-
dual to the Stiefel-Whitney 2-class, right, i.e., a cocycle w^
with : w^\/ c = c\/c , where \/ is cupping? (duality of course, when
the ambient manifold is an orientable, etc. 4-manifold)
A quick followup, please:
It would seem that if there was no torsion, then, by the Universal Coefficient
Theorem of Homology, every Z/2 chain is the reduction of a Z-chain. Is this
a necessary and sufficient condition for an isomorphism between the chain groups?
Also: it seems like there is a relationship between simple-connectedness and 1-torsion
that also follows from the Universal Coefficient Theorem. Is this a fact?
Thanks.
Thanks.
If there is no torsion then then Bockstein sequence looks like
0 -> H_i(M:Z) -> H_i(M:Z) -> H_i(M:Z/2Z) -> 0
Bacle said:
Thanks, both.
Your statement confuses me but ... I think it is true that Poincare duality works mod2 whether or not the manifold is orientable. This probably is because the tangent bundle of any manifold is orientable mod 2. So the 2'nd Stiefel-Whitney class is dual to a 2 chain - mod 2. If one triangulates the manifold then takes the first barycentric subdivision of the triangulation then this dual chain is just the mod 2 sum of all of the 2 simplices in the subdivision.
The duality map is - evaluating a mod 2 cocycle on the dual 2 chain is the same as cupping the cocycle with the 2'nd Stiefel-Whitney class and evaluating on the mod2 fundamental 4 cycle.
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 93 ·
17K
  • Poll Poll
