Electric field inside conductor?
The discussion centers on the concept of electric fields inside conductors, particularly addressing why there is no electric field in a conductor at electrostatic equilibrium. Participants explore the motion of charges within conductors, the conditions under which electric fields exist, and the implications of external electric fields on charge distribution.
  • Some participants assert that charges inside a conductor redistribute to achieve electrostatic equilibrium, resulting in no electric field when in equilibrium.
  • Others argue that the absence of an electric field only applies when the conductor is in equilibrium and that there can be an electric field present during charge redistribution when an external field is applied.
  • One participant questions the assumption that charges inside a conductor are solely electrons, highlighting the presence of positively charged nuclei and the balance of forces acting on electrons.
  • A later reply discusses the behavior of charges in a charged conductor, noting that additional charges redistribute themselves quickly to maintain zero electric field inside the conductor.
  • Another participant seeks clarification on why net positive charges move to the boundary of a charged conductor, prompting further exploration of the forces at play.
Participants express differing views on the conditions under which electric fields exist inside conductors, with some asserting that equilibrium leads to no electric field, while others emphasize the transient states during charge redistribution. The discussion remains unresolved regarding the underlying reasons for charge movement in various scenarios.
Participants note that the discussion primarily focuses on electrostatics and does not address transient behaviors in detail. The assumptions regarding charge distribution and the nature of forces acting on charges are also highlighted as areas of complexity.
wangdang
Hi all,
I need some help understanding why exactly there is no electric field inside any conductor (charged or uncharged). I am in year 12, and I would like to understand the reasoning behind it in terms of the MOTION OF CHARGES in the conductor.
What I know so far:
- Charges (electrons) inside a conductor will repel (Coulomb's law).
- The charges will experience repulsion which results in maximum separation distances between the charges.
- The charges will then redistribute along the surface of the conductor in order to achieve electrostatic equilibrium (ie. net force of zero on each charge)
- Thus, no electric field exists inside the conductor.
Please feel free to correct me if I am wrong in any of the above statements.
Appreciate the help. Thanks.
hi wangdang! :wink:
Often quoted, but not true: it only applies in equilibrium.
When a charge is first brought near a conductor, the free charge inside the conductor rearranges itself extremely quickly to cancel out the field … while this is happening, of course there is a field!
And of course there is an electric field inside every current-carrying wire.​
In equilibrium, by definition, a free charge inside the conductor will not move
that is simply another way of saying that there is no electric field :smile:
High school physics is wrong yet again :(
I am not sure I quite understand you though. Since there is free charge inside a conductor, wouldn't it redistribute to achieve equilibrium. Why must a charge first be brought near the conductor?
if there is no external field, it doesn't need to redistribute
when you apply an external field (bringing a charge near the conductor is just an example), then yes the charge will redistribute
when it stops redistributing, by definition there is no electric field, and there is equilibrium
But don't the charges (electrons) inside the conductor repel; thus redistribute?
i don't understand what you mean by "redistribute" …
the conductor contains billions of negatively-charged electrons and positively-charged nuclei …
in the natural state, the electrons are attracted to the nuclei, and they stay there …
the repulsive force from other electrons all around one electron is roughly the same as the attractive force of all the other nuclei …
i think you're assuming that the electrons are the only free charges inside the conductor :redface:
That was exactly was I was assuming. Thanks a lot for clearing that up!
Hi, sorry for bumping this, but my question is related to this.
Isn't the above explanation only true for an uncharged conductor? Supposing the conductor had a net positive charge Q. How would the explanation proceed then?
If you charge a conductor, these additional charges indeed redistribute themselves within short times such that there's no electric field inside the conductor (Faraday-cage effect).
^What's the reason? I get it that it's happening. What I need to know is WHY the net positive charge Q is moving to the boundary of the conductor.
because it can't move any further …
if it could, it would! :smile:
My question isn't why the boundary - my question is why is it moving at all? When there's no net electric field OUTSIDE, why do the charges rearrange at all such that the field inside is zero ?
When you initially apply an electric field across a conductor then there is a net field on the interior of the conductor. This induces a force on the electrons in the conductor via the Lorentz force which causes the electrons to move in response. As time passes, the electrons will arrange themselves so that the interior of the conductor has no net electric field. Since we generally discuss this topic in terms of electrostatics, there is no transient behavior. When we look at the problem the electric field has already been applied for a "very very long" time and the conductor's charges have already reached their equilibrium state.
  • · Replies 21 ·
