Angular motions and Dynamics - centripetal acceleration
The discussion revolves around calculating the maximum speed of a train traveling around a bend with a specified radius, while ensuring that the centripetal acceleration does not exceed a certain limit for passenger comfort. The subject area includes concepts from dynamics and centripetal motion.
  • Participants discuss various equations related to centripetal acceleration and attempt to apply them to find the maximum speed. There are questions about the correct interpretation of variables, particularly the meaning of 'g' in the context of the problem.
Several participants have shared their attempts at solving the problem, with some expressing confusion about the calculations and the units involved. Guidance has been offered regarding the proper setup of equations and the importance of using standard units. There is an ongoing exploration of different methods to arrive at the correct answer.
Participants note the challenge of converting between units and the need to clarify the definition of 'g' as the acceleration due to gravity, rather than grams. There is also mention of the constraints imposed by the homework requirements.
hussey1
Hi all ,
I'm new here, studying computer aided product design and in my second year. We do a lot of physics and maths. I am stuck on a current question, probably not too hard but I am struggling to know what to do and the lecturers notes are not very helpful.
Calculate the maximum speed in km/h at which a train may travel around a bend of 100m radius if the maximum centripetal acceleration must not exceed 0.1g in order to maintain passenger comfort.
Centripetal acceleration = V^2 / r
2 x Pi x r
radian to degree = X x 180/pi
Attempted using above equations and tried different methods the closest I got to the answer is:
2 x pi x r
= 2 x pi x 100
= 628 = 0.628km
0.628 x 180/pie
=35.98
I have the answer but just can't quite get it, the answer is: 35.66 km/h
Other methods I tried are here (I know they are not correct, but I tried anyway):
0.1g= V^2 / r
0.1g = V^2 / 100m
V^2 = 0.1g x 100m
V^2 = 10 (g/m?)
v = Square root of 10
V = 3.16
I also used the same as above but put this in the equation 0.1 x 9.81 = 0.981 and I got 0.99
Many thanks in advance
Ollie
2 x pi x r
= 2 x pi x 100
= 628 = 0.628km
0.628 x 180/pie
=35.98
I don't understand what you did here.
This is the equation you need:
Set it up and solve for V.
0.1g= V^2 / r
0.1g = V^2 / 100m
Now you're on the right track. Hint: What is 'g'?
When dealing with these equations, express everything in terms of standard units: meters and seconds. You can convert to other units later.
Thank you, I tried using that equation, and just edited my post above while you were posting, but I still didn't get the right answer?
Yep. See my comment above.
I tried g as gravity above? I guess this is incorrect is g grams?
'g' is the acceleration due to gravity. What does it equal? (Look it up!)
(No, g is not grams!)
Thank you, yes I tried with gravity as above "I also used the same as above but put this in the equation 0.1 x 9.81 = 0.981 and I got 0.99" But I still did not get the correct answer.
I have done this:
0.1g= V^2 / r
0.1x(9.81) = V^2 / 100m
V^2 = 0.981g x 100m
V^2 = 98.1
v = Square root of 98.1
V = 9.9
Also put in as km/h 35.3 and got v= 18.78
I have done this:
0.1g= V^2 / r
V^2 = 0.981g x 100m
V^2 = 98.1
V = 9.9
Good! The speed here is in standard units of m/s; you'll need to convert to km/hr.
Thank you, I appreciate the help! Got the answer now!
I think I was thinking it was more complex than it actually was and thinking into it too much!
Thank you again!
  • · Replies 28 ·
