De-Ionized Water: Duration, Storage, and Ionization Factors Explained"
  • Context: High School
  • Thread starter Thread starter banerjeerupak
    Water
The discussion revolves around the duration that de-ionized water remains de-ionized, factors affecting its ionization, and the implications of storage materials. Participants explore the effects of container choice and environmental conditions on the purity of de-ionized water.
  • One participant inquires about the time frame in which de-ionized water begins to ionize again, acknowledging that this may depend on storage conditions.
  • Another participant provides a detailed explanation of deionized water, noting that it is produced through ion exchange resins and highlighting its high purity, while also mentioning that it does not remove uncharged organic molecules or bacteria effectively.
  • A participant challenges the idea that sealed de-ionized water remains uncontaminated, suggesting that the water may dissolve the container material, affecting its purity.
  • There is a discussion about the common storage materials for de-ionized water, with some participants mentioning glass and others expressing concerns about the interaction between de-ionized water and glass.
  • One participant reflects on the corrosive nature of de-ionized water and expresses a desire for a specific time scale regarding its purity, while acknowledging that the discussion has enhanced their understanding.
  • Another participant asserts that de-ionized water does not dissolve glass, although they admit to not having verified this claim.
  • A later reply emphasizes the difficulty of maintaining high resistivity in de-ionized water, suggesting that purity is challenging to sustain over time.
Participants express differing views on the effects of storage materials on de-ionized water, with some asserting that glass is safe while others caution against it. There is no consensus on a specific time frame for how long de-ionized water remains pure.
Participants note that the purity of de-ionized water is influenced by various factors, including the type of container and environmental conditions, but do not reach a definitive conclusion on the time scale for ionization.
banerjeerupak
Hi,
How long does de-ionized water remain de-ionized. After what amount of time would it start geting ionized again. I understand that it would greatly depend on the container in which it is kept and the environmental conditions. However, the order of the time would help me.
Thanks.
Deionized water, also known as demineralized water[2] (DI water, DIW or de-ionized water), is water that has had its mineral ions removed, such as cations from sodium, calcium, iron, copper and anions such as chloride and bromide. Deionization is a physical process which uses specially-manufactured ion exchange resins which bind to and filter out the mineral salts from water. Because the majority of water impurities are dissolved salts, deionization produces a high purity water that is generally similar to distilled water, and this process is quick and without scale buildup. However, deionization does not significantly remove uncharged organic molecules, viruses or bacteria, except by incidental trapping in the resin. Specially made strong base anion resins can remove Gram-negative bacteria. Deionization can be done continuously and inexpensively using electrodeionization.
Deionization does not remove the hydroxide or hydronium ions from water. These are the products of the self-ionization of water to equilibrium and therefore are impossible to remove.
http://en.m.wikipedia.org/wiki/Purified_water
So as long as you keep the water sealed and all that, your water is kept clean. No "order of time" or whatever.
No, the deionized water will immediately begin dissolving the container in which it is sealed. To see how fast this occurs, measure the water's resistivity as it falls from a maximum of about 18 MΩ-cm.
isn't DI water usually kept in glass bottles?
Not in my lab. I don't want all the components of soda-lime glass in my DI water!
Thanks for the insight. The replies have all helped a lot. I understand that it is highly pure form of water. And it is quite corrosive too due to the attraction it shows to ions in whichever container it is kept in. I am keeping my DI water in plastic containers. I was hoping for a time scale such as "it no longer remains essentially DI after about a week". But this question has improved my understanding off the DI water
In mine it's kept in glass bottles (or more appropriately, a gigantic glass vat). And it doesn't dissolve glass anyway. I think. Haven't yet checked, hmm... =P
Be sure it does. Keeping water at 18 MΩcm is not an easy task.
  • · Replies 35 ·
10K
  • · Replies 26 ·
