Is the close interval A=[0,1] is compact?
  • Thread starter Thread starter rohan302
    Compact Interval
The discussion revolves around the compactness of the closed interval A=[0,1] in the context of different topological spaces, particularly focusing on the Heine-Borel theorem and its applicability.
  • One participant asserts that the closed interval A=[0,1] is compact, referencing the Heine-Borel theorem.
  • Another participant notes that while (0,1) is not closed but bounded, its closure leads to the closed interval, thus supporting the compactness property.
  • A further contribution emphasizes the necessity of specifying the topology when discussing compactness, stating that under the usual topology on the real numbers, the interval is compact, but under the discrete topology, it is not compact despite being closed and bounded.
Participants express differing views on the compactness of the interval depending on the topology considered, indicating that there is no consensus on the matter without specifying the topology.
The discussion highlights the importance of topology in determining compactness, with specific reference to the Heine-Borel theorem and its limitations in non-standard topologies.
rohan302
(0,1) is not closed, but it's bounded. So taking its closure in the interval metric one gets the closed interval hence the compactness property.
Assuming you are talking about the "usual topology" on the real numbers (the metric topology defined by the metric d(x,y)= |x- y|) then, yes, that set is both closed and bounded and the Heine-Borel theorem applies, so it is compact.
But it is necessary to specify the topology, not just the set. While the topology I cited above is the "usual" topology, we could also give the set of all real numbers the "discrete" topology which is the metric topology defined by "d(x, x)= 0 but if [itex]x\ne y[/itex] d(x,y)= 1". Then it is easy to show that every set is closed and every set is bounded but the only compact sets are the finite sets. In that topology, [0, 1] is both closed and bounded but is not compact. Obviously, the "Heine-Borel theorem" does not apply in that topology.
  • · Replies 24 ·
