Anyone know anything about Glass Polishing/Scratch removal?
  • Thread starter Thread starter Saladsamurai
    Glass
The discussion centers around methods for polishing and removing scratches from glass viewing windows used in a combustion chamber, particularly those affected by the corrosive effects of combustion products. Participants explore various techniques and materials for both repair and protection of the glass.
  • Experimental/applied
  • One participant describes the glass windows as having mild erosion due to acidic combustion products and seeks advice on polishing methods.
  • Another suggests using tin oxide powder for polishing, recommending the use of a plate glass tool to maintain flatness.
  • There is a proposal to use a sacrificial liner made of acrylic to protect new windows from damage.
  • A participant warns that Lexan, while shatter-resistant, is soft and may not withstand mechanical abrasion, suggesting caution in its use.
  • Discussion includes the etching properties of hydrofluoric acid on glass and polycarbonate, with suggestions for protective coatings like Teflon or diamond CVD.
  • One participant shares a personal experience with a glass repairer who used a specific method involving flat belts and water for effective polishing.
  • Another mentions the availability of aquarium scratch removal kits for both glass and acrylic as a potential solution.
Participants express a range of opinions on the best methods for polishing and protecting the glass, with no consensus reached on a single approach. Multiple competing views and suggestions remain present throughout the discussion.
Some participants highlight the limitations of certain materials in relation to hydrofluoric acid, indicating that compatibility and effectiveness of proposed solutions may vary based on specific conditions and requirements.
Saladsamurai
In my lab we have these glass viewing windows that are affixed to a combustion chamber. We've recently been experimenting with some new fuels that have some pretty nasty products of combustion. As a result, the windows have become "cloudy."
At first, I thought it was just a nasty film that had developed on the glass, but it is actually some very mild erosion that is occurring (likely due to the acidic nature of the HF in the products).
These windows are quite expensive as they are 1.5 inches thick and are made of fused silica. Though we have ordered new glass, cleaning these up seems like a great idea.
Anyone have any experience with glass polishing that could make a suggestion as to where to start on this one?
What kind of products should I be looking into?
Have you thought about using tin oxide powder? To preserve the flatness of the windows, you night have to apply the tin oxide using a piece of plate glass as a tool. You might haunt the amateur telescope making sites for sources of polishing compounds.
If you want quick-and-dirty, you could try something like this:
http://www.properautocare.com/polishglass.html
No idea how to fix up the old ones. But when the new ones are installed, I'd try to find a way to protect them from a similar fate. Maybe put in a cheap sacrificial liner (acrylic or ?) that could easily be replaced once it gets ruined.
Thanks for the replies folks :smile: I am not too concerned with the new ones as they will not be used with these fuels. I think we may have to use windows of a different material altogether for these other fuels (perhaps some kind of plastic as I hear hydrofluoric acid does not react with plastic like it does with glass).
I figure if I can get these windows polished up a little, I could dedicate them specifically to the newer damaging fuels until a more permanent solution comes about.
Be aware that if you use Lexan windows, that material is quite soft. It is highly shatter-resistant, but that toughness does not equate to resistance to mechanical abrasion. When I was a dispensing optician, I always suggested Lexan lenses for kids because of the shatter-resistance, though I'd have to educate them and their parents in the proper cleaning/maintenance of that eyewear.
HF is used as an etchant for glass / silica / quartz. Even in the gas phase, it can do some damage. Etching also tends to result in etch products that partially mask sites on your glass so that it 'frosts' (like in decorative windows) and otherwise renders originally-transparent pieces of these materials partially or fully translucent.
You'll have to find a protective coating for your glass to keep this from happening (if that's a concern), and still survive the high temperatures the system is working at (I assume, since you mention this is a combustion chamber). Teflon or kapton coating? Diamond CVD (if the glass piece is small enough, and there's CVD system that can do it)?
Unfortunately, hydrofluoric acid will also etch polycarbonate (lexan) and isn't so great for PVC either (just select hydrofluoric acid, 20% to get an idea of what it is and is not compatible with):
http://www.coleparmer.com/techinfo/chemcomp.asp
As for polishing up your existing pieces, I'd suggest looking for glass shops in your area--particularly, scientific or artistic would probably be better than the ones that install windows and the like.
My wife and I used to sell Murano (Venetian) Glass sculptures and had to repair some damaged items. We found a glass repairer in the phone book. I watched him work, he used 2 long flat belts on pulleys, with running water. One had a very fine abrasive, the other was for polishing after the first. Did a great job and was very cheap. I took 4 sculptures for repair, the largest being almost a metre long, the smallest about 15cm (6") in dia. an hour and a half later, all 4 items were repaired for a cost of AU$90.
you can get aquarium scratch removal kits for either glass or acrylic.
9K
