What Is the Key Principle of the Michelson/Morley Experiment Apparatus?
  • Thread starter Thread starter Shark 774
    Experiment
The key principle of the Michelson/Morley experiment apparatus is that the components must not move relative to each other (D). This is crucial because any movement could lead to ambiguity in interpreting shifts in the interference pattern, making it difficult to determine if the shift is due to the movement of the apparatus or changes in the aether. While options A, B, and C present relevant considerations, they do not address the fundamental requirement of maintaining a stable configuration during measurements.
  • Understanding of interferometry principles
  • Familiarity with the concept of aether in physics
  • Knowledge of light behavior and wave interference
  • Basic grasp of experimental design in physics
  • Research the principles of interferometry in detail
  • Study the historical context and implications of the Michelson/Morley experiment
  • Explore the concept of aether and its relevance in modern physics
  • Learn about precision measurement techniques in experimental physics
Physics students, experimental physicists, and anyone interested in the historical experiments that shaped modern physics theories.
Shark 774
Which one of the statements below specifies the critical basis of the apparatus used in the Michelson/Morley experiment?
A) The half-silvered mirror must reflect exactly half the light.
B) Mirror 1 and mirror 2 must be identical.
C) The distance traveled by light using either path must be equal.
D) The components must not move relative to each other.
I don't think A or B are right. If the different distances were known C would be fine. If the relative speeds and distances between parts were known then D should also be fine, I would think. Any ideas?
D is not fine. If the components of the interferometer moved, and you observed a shift in the interference pattern, how would you know whether the shift was due to the components moving or due to the aether changing direction relative to the device? In theory, you can precisely measure the movements of the interferometer's components and account for them. In practice, it's impossible to measure sub-micrometer movements that precisely.
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 16 ·
