SnowOwl18
- 71
Alrighty, here is a problem I am stuck on.
----A 21.0-kg body is moving in the direction of the positive x-axis with a speed of 274 m/s when, owing to an internal explosion, it breaks into three pieces. One part, whose mass is 7.5 kg, moves away from the point of explosion with a speed of 428 m/s along the positive y axis. A second fragment, whose mass is 3.5 kg, moves away from the point of explosion with a speed of 483 m/s along the negative x axis. What is the speed of the third fragment? Ignore effects due to gravity.-----
Ok...so the momentum in the positive x direction before the explosion was p=mv...or 21x274= 5754 kg*m/s...i think the y direction is irrelevant in the problem, since momentum in the x-axis is conserved...so assuming that, i do the equation 3.5kg x (-483 m/s) + 10kg x V3 = 5754 kg*m/s...the 2nd fragment's velocity is negative because it goes along the negative x axis...and the third fragment's mass is 10kg because 21-7.5-3.5 = 10kg. Anyway, I solved for the third fragment's velocity (V3) and got an answer of 744.45 m/s...but the computer program says I'm wrong. Does anyone know what I'm doing incorrectly? And if so, how do I go about the problem the correct way? Thanks so much. :D
