What is the tension in a child's neck while sliding down a water slide?
The discussion revolves around the tension in a child's neck while sliding down a water slide, specifically focusing on the forces acting on her head during the slide. The subject area includes concepts of tension, centripetal acceleration, and forces in a horizontal curve.
  • Participants discuss the forces acting on the child's head, including the need for tension to balance weight and provide centripetal acceleration. There are attempts to relate the problem to the mass of the head and the equations of motion.
Some participants have offered insights into the relationship between tension, weight, and centripetal force. There is an ongoing exploration of the problem with various interpretations and approaches being discussed, particularly regarding the assumptions made about the forces involved.
Participants note that the tension must balance both the weight of the head and provide the necessary centripetal force, indicating a complexity in the problem setup. There are also references to additional questions related to a plumb bob and its deviation due to Earth's rotation, which may indicate a broader context of forces and motion being explored.
hL
A child is lying on her back. The tension in the muscles of her neck is 55N as she raises her head to look past her toes and out the motel window. Ten minutes later she is screaming and sliding feet first down a water slide at a constant speed of 5.7 m/s in a horizontal curve of radius 2.40 m. She raises her head to look forward past her toes; find the tension in the muscles in her neck.
Thanks in advance!
First case:
The tension provides the necessary force to balance the weight of the lifted part of her body (for simplicity, let's call that "the head" in the following)
Use this to determine the head's mass.
For the second case:
Note that when her head does NOT touch the slide, only the tension in her neck provides the force necessary for the centripetal acceleration the head experiences.
So I would do the second part of the problem focusing around the head? Gotcha.
It'd be T=mv²/r, using the mass of her head I think. Thanks for responding.
That's what I had in mind..
Welcome to PF, BTW.
If you wouldn't mind helping me again, I have another question that I'm stumped on.
A plumb bob does not hang exactly along a line directed to the center of the Earth because of the Earth's rotation. How much does the plumb bob deviate from a radial line @ 35 degrees north latitude? Assume the Earth is spherical.
I combined the x and y components of the bob to get (4*pi²*r)/(T²g) = tan(x). What numbers would I use for r and T? I think I could use 24 hrs. for T, but r wouldn't be the Earth's radius.
EDIT: Thanks for the welcoming. :smile:
First of all:
We both forgot that the tension in the first exercise b) ALSO must balance the weight, not only provide the centripetal acceleration..
You're right, r is the planar radius at 35 degrees latitude
tension in the first exercise ALSO must balance the weight
Since it's a horizontal curve, the weight, down, should be balanced by a frictional force, up. I think that's how it works in a certain amusement park ride whose name escapes me at the moment.
Your head is FREE, is it not?
(only connected to your body, not in touch with the slide, the only force which acts upon it other than the weight, is whatever your neck imparts to it..)
I see what your saying now. Thanks, I'll grind through this problem later tonight.
Note for Plumb bob question if it helps( i got the right answer using this)
It seems to work, since the angles aren't perpindicular
C(Force of Tension)^2 =A(gravity)^2 +B(4pi^2 r(planar radius)/T^2 )^2 -2ABCOS(θ(which is 35º))
Then use Sin Law to find the angle that the plumb bob deviates
9K
12K
