Solving Quaternion Confusion for 3D Orientation
  • Context: Graduate
  • Thread starter Thread starter SGGSJi
    Confusion Quaternion
The discussion revolves around the interpretation of quaternion values received from a motion sensor in relation to 3D orientation. Participants explore the relationship between quaternion outputs and sensor position, specifically addressing whether translation affects quaternion values when no rotation occurs.
  • One participant questions whether the quaternion values should remain the same when a sensor is translated without rotation, noting that different quaternion values are observed.
  • Another participant clarifies that quaternion outputs represent orientation only and do not account for position, suggesting that differences in quaternion values could arise from sensor error or unintentional rotation.
  • A participant mentions attempting to convert quaternion outputs to Euler angles, but finds significant discrepancies, indicating confusion about the expected results.
  • One participant proposes a method to set Euler angles to zero for a given location using quaternion operations, suggesting that ideally, both locations should yield the same Euler angles if no rotation occurs.
  • A later reply recommends contacting the sensor manufacturer for clarification on quaternion outputs and suggests looking for equations that relate quaternion components to Euler angles.
Participants express differing views on the relationship between quaternion values and sensor translation, with some asserting that orientation should remain unchanged while others highlight potential errors or misunderstandings in sensor readings. The discussion remains unresolved regarding the expected behavior of quaternion outputs in this context.
Participants note that the quaternion outputs are referenced to global north, which may affect the interpretation of Euler angles. There is also mention of potential sensor errors and the need for further clarification on the sensor's intended output.
SGGSJi
Hi Guys,
I am getting a quaternion stream from motion sensor (accl, gyro, magneto). As I understand the quaternion represent the 3D orientation of objects. When I place the sensor at location 1 (I record quaternion, q1=[w x y z]), now if I place it at location 2 (say 3 feet to right, 2 feet up and 2 feet forward, q2=[w2 x2 y2 z2]) basically no rotation just translation, should I be expecting same quaternion values as location 1?
I get two different quaternion values, assuming that is correct. I wish to determine if there is any difference in orientation(Euler angles) at location1 and 2. Any ideas where I might be wrong.
Please guide.
Regards,
The quaternion output only describes the sensor orientation. It has nothing to do with position. If the two quaternions are different either: you did in fact rotate it, or the sensor has some error. I don't know what kind of sensor you have, but in general these things are always trying to balance a pure tilt measurement with rate sensor integration.
Change the quaternion outputs back in euler angles so that you have a better understanding of the difference. Maybe you are seeing a small angle difference.
Thank you
I was making sure that I don't rotate the sensor. I even tried converting quat output to Euler but the values were way different. Please note that as the quat values are with repect to global north the Euler angles were random, however the Euler angles for both locations should still be same. I believe to set euler angles to zero for a given location I should do the following
Q1= quat at location 1
Q1'= conjugate of Q1
Qnew= multiply (Q1', Q1)
Q2= quat at loc 2
Q2new= multiply(Q1',Q2)
Then Euler angles would be
EulerQ1= 0 0 0
EulerQ2= 0 0 0 ( ideally if no orientation at loc 2)
Hmm, at this point, I'd recommend getting in touch with tech support of the sensor manufacturer. I think the quaterion output is intended to be a simple representation of the orientation as a function of time, and is not a transformation from one reading to the next. You should be able to find a set of equations to express the Euler angles in terms of quaternion components. I'd be surprised if the manual didn't have something similar.
