Air flow through increasing pipe size
The discussion revolves around modeling air flow and pressure changes in a pneumatic system with varying pipe sizes. Participants explore the implications of transitioning from a smaller diameter hose to a larger inlet on pressure loss and flow characteristics, considering both theoretical and practical aspects.
  • One participant notes that pressure drops when the pipe size decreases, suggesting a rough estimate that doubling the pipe size could halve the pressure, but acknowledges uncertainty.
  • Another participant agrees that reducing pipe size increases velocity and decreases pressure, but expresses confusion about the mechanics involved.
  • A participant uses an analogy of cars in lanes to illustrate the concept of flow rate and velocity changes when transitioning between pipe sizes.
  • One participant references Bernoulli's law as a governing equation for non-extreme flow rates, indicating that pressure and flow velocity are the key variables affected by pipe diameter changes.
  • Another participant mentions the Darcy-Weisbach equation as a method for calculating pressure drop, but expresses doubt about its applicability for sudden diameter changes without considering length.
  • A later reply indicates that while the Darcy-Weisbach equation may not directly address the participant's needs, the referenced document could still be useful for future reference.
Participants generally agree that changes in pipe diameter affect pressure and flow characteristics, but there is no consensus on the specific equations or models to apply, particularly regarding sudden changes in diameter.
Participants express uncertainty about the assumptions underlying their reasoning, particularly regarding the applicability of certain equations to their specific scenario involving sudden diameter changes.
bigbsonnier
Air flow in shop is through 1/4" hose. pneumatic motor has 1/2" inlet plus the tubeing to and from valve is also all 1/2" tube. what would be a general equation to model the pressure loss or increase to the motor.
Shop air:
80psi 60cfm
So looking back a bit or lot more paper education would have been good for me but, I say the pressure drops for sure (put thumb over garden hose it increases). But, how much, don't know. I would guess double the pipe you half the pressure.
I am pretty flighty with my passions. So I got it in my head to use my natural math (just above zero to many of you I'm sure) ability, the generic teaching system and this here internet to grow my understanding to at least where I can understand what is being said in those beautiful numbers. I might be a bit of a pain on here for a bit.
"I would guess double the pipe you half the pressure. "
But don't quote me on that...
well i know when you decrease the pipe size and volumetric flow rate remains constant - velocity increases and pressure drops, i would assume the inverse is true with a distinct loss of energy but I'm unsure as to the driving equation as every "online calculator" throws a fit if you go small to big versus big to small.
Really? Same volume going through smaller pipe. I can't get my head around this quite yet.
take it like 4 lanes of cars going down to 2 lanes and the cars are invencible and the cars continue to come at a steady rate, basically for the system to work the cars moving into the 2 lane section will have to move faster. that analogy handle the mass but not the pressure but you get the idea right?
If you want a governing equation, Bernoulli's law covers this for non-extreme flow rates.
[itex] \[ P + \frac{1}{2}\rho v^2 + \rho g h = constant\][/itex]
In your case the only variables changing from one tube to the other are the flow velocity and the pressure, both of which you can work out from your pressure and tube diameter data if you also know the volumetric flow rate..
Pressure drop through pipe or tube is generally done per the Darcey Weisbach equation which is given by equation 1 in the attachment called "Pipe-Flo Pro.PDF" https://www.physicsforums.com/showthread.php?t=179830".
Thank you for the info on the document i think it may be invaluable to me in the futrue, however right now i don't believe the DW equation is what I am looking for, unless there is a way of restating it that works for my case.
I'm trying to get the dp with the sudden change of diameter. Length is not my conern right now.
I have read through the entire document yet so the answer may yet be in there but thank you any way because i know i'll use it in the future.
