Linear momentum- is my answer correct?
The discussion centers on a physics problem involving two blocks with masses of 1 kg and 4 kg colliding on a frictional surface, with a spring attached to the 4 kg block. The calculated maximum compression of the spring after the collision is 0.396 m, based on the conservation of momentum and energy principles. However, there is a discrepancy with a review book that claims the final velocity of the blocks should be 53.6 m/s, which is deemed excessively high by participants. The consensus suggests that the final velocity should be 5.6 m/s, indicating a misunderstanding in energy transfer during the collision.
  • Understanding of conservation of momentum in inelastic and elastic collisions
  • Knowledge of kinetic energy and potential energy relationships
  • Familiarity with Hooke's Law and spring constants
  • Basic algebra for solving equations
  • Review the principles of conservation of momentum in elastic and inelastic collisions
  • Study the relationship between kinetic energy and potential energy in spring systems
  • Learn about Hooke's Law and its applications in collision problems
  • Explore common misconceptions in physics problems involving energy transfer
Students studying physics, educators teaching mechanics, and anyone interested in understanding collision dynamics and energy conservation principles.
imatreyu
Two blocks with masses 1 kg and 4 kg, respectively, are moving on a horizontal frictional surface. The 1-kg block has a velocity of 12 m/s, and the 4-kg block is ahead of it, moving at 4m/s. The 4 kg block has a massless spring attached to the end facing the 1-kg block. The spring has a force constant k equal to 1000 N/m.
a. What is the maximum compression of the spring after the collision?
b. What are the final velocities of the blocks after the collision has taken place?
conservation of momentum (inelastic and elastic)
a.
For an instant, the collision is inelastic
mv1i + Mv2i = (m+M) vf
Solve for vf--> vf= 5.6 m/s
All kinetic energy goes into compressing the spring:
.5mv^2=.5kx^2
--> mv^2=kx^2
(m+M)vf^2=1000N/mx^2
Solving for x gets .396 m.
My review book uses the same method as me but says that final velocity should be 53.6 m/s. And thus, x= .05 m. Am I correct or is the book correct? Also, it doesn't matter what units mass is in, right?
The final velocity of what is supposedly 53.6 m/s? Surely not the 4kg block?
imatreyu said:
a.
This part seems correct to me, although I wouldn't call it 'for and instant'. It's the total time for the spring to compress. But maybe we're talking semantics here.
.5mv^2=.5kx^2
I think you should reconsider this part. If all the kinetic energy goes into the spring as potential energy then both blocks would be at rest. However, both blocks were moving in the same direction and had a collision. By what mechanism would would both blocks come to rest? Even if the 1kg block was brought to a stop by the spring force, the 4 kg block would be pushed from the rear increasing its velocity. I think it would be correct to say that 'some of the kinetic energy goes into compressing the spring.'
gneill is skeptical of this answer and so am I. I think it's way too high. I got an answer that was less than 10m/s.
  • · Replies 31 ·
18K
