| New Reply |
how is it called this function ?? |
Share Thread | Thread Tools |
| May9-11, 02:34 PM | #1 |
given a number 'n' how is it called this function [tex] P(n,k) [/tex]
so P(n,k) is the number of ways in which an integer 'n' can be expressed as the sum (with repeated summands) of k integers different or not then for any integers n and k how could i compute [tex] P(n,k) [/tex] ? is there a recurrence equation ?? |
| May9-11, 06:34 PM | #2 |
Would it be useful for you to restrict n and k to be positive integers? If so, then you're dealing with the theory of partitions. (If you allow negative integers, then you get infinitely many solutions. Say n = 5 and k = 3. In addition to solutions such as 5 = 3 + 1 + 1, you also get 5 = 5 + 1 + (-1) = 5 + 2 + (-2) = 5 + 3 + (-3), and so on.)
Assuming that you're interested in the case where n, k are positive, we have the following Theorem: The number of partitions of n into k parts is equal to the number of partitions of n into parts the largest of which is k. The proof is to consider the Ferrers diagram (see the Wikipedia article for the definition) of such partitions. It's now easy to simplify your function P(n,k) (By the way, the Wiki article uses P(n,k) for a different function). Let P(n) be the number of unrestricted partitions of n. Then P(n,k) = P(n-k) The proof is simple: For each partition of n in which the largest part is k, we have a corresponding partition of n - k. In other words, if [tex]n = k + k_1 + k_2 + \cdots + k_m[/tex] then [tex]n - k = k_1 + k_2 + \cdotd + k_m[/tex] Thus, you can translate P(n,k) into P(n-k) and use all of the techniques and such from partition theory, only a small part of which is described in the Wiki article. HTH |
| May10-11, 02:58 AM | #3 |
ok thanks ... :)
| May10-11, 04:20 AM | #4 |
| May10-11, 06:03 PM | #5 |
| New Reply |
| Thread Tools | |
Similar Threads for: how is it called this function ??
| What is this called? | General Physics | 3 | ||
| Can someone tell me what this is called? | Linear & Abstract Algebra | 5 | ||
| What is this called? | General Discussion | 1 | ||
| What are these called? And do you have one to add? | General Discussion | 22 | ||
| What is it called please | General Math | 4 | ||
