Question on Photoelectric effect
The discussion revolves around the photoelectric effect, specifically focusing on the kinetic energy of electrons emitted from an aluminum surface when exposed to light of a certain intensity and wavelength. Participants are exploring the relationship between photon energy, work function, and the resulting kinetic energy of emitted electrons.
  • Participants discuss the calculation of the minimum kinetic energy of electrons and question the concept of partial absorption of photons. There is exploration of the relationship between photon energy, work function, and the energy levels of electrons below the Fermi level. Some participants attempt to derive equations related to photon intensity and the number of photons striking the surface.
There is an ongoing exploration of concepts related to the photoelectric effect, with participants questioning their understanding of kinetic energy, the role of the Fermi level, and the implications of photon energy. Some guidance has been provided regarding the definitions and relationships involved, but multiple interpretations and uncertainties remain in the discussion.
Participants are working within the constraints of a homework problem, which includes specific values for intensity, wavelength, and work function. There is a focus on understanding the underlying physics without reaching definitive conclusions.
stunner5000pt
Light of intensity 2.0 W/ m^2 is incident on an aluminim surface. The wavelength of the light is 160nm. For aluminium the work function is 4.2eV.
Find the kinetic energy of the slowest moving electrons
So then Kmin would be the wavelength at which the cutoff frequency occurs, yes?
e = hf -> e = hc / lambda and E = 4.2eV = hc / lambda then find the cutoff wavelength?
At this point I am stumped still... please do help thank you in advance!
Heres another one part b of this question
Fidn the average rate per unit area at which photons strike the aluminium surface
P = E / t = hf / t = hc / lambda t and lambda = 160nm.
I = P / A = hc / lambda t A. I know intensity, h ,c , lambda and all i need is something over t A giving units of per second per sq m
Am i right? input would be greatly appreciated!
I hink i figured out that Kmin would be zero for the slowest electron because the sloest electron may not absorb the photon of the highest energy instead it may absorb the photon partially(?)
but i am not sure if this reasoning is correct?? please help!
There are no partial absorption. So flush this thought out of your head.
The electrons in the metals are distributed over a range of energy below what is known as the Fermi energy. The most energetic photoelectrons that one obtains came from this Fermi energy level. These are the electrons that had KE of h*nu - phi, the most energetic ones.
However, it doesn't mean that the incoming photons cannot also excite electrons from below the Fermi level. Let's say these electrons are at an energy level epsilon below the Fermi level. Thus, these electrons, when they are emitted, will have an energy h*nu-phi-epsilon, which is now LESS than the most energetic one. The deepest level below the Fermi level that can be emitted will be when h*nu-phi-epsilon = 0.
Zz.
Zz.
IS epsilon a difference then?
iknow h nu, phi but i don't know epsilon so i can find that out. But how would epsilon lead to kinetic energy??
If you don't like "epsilon", call it anything you want. It is just the energy level BELOW the Fermi level, as I've defined earlier.
Zz.
still not getting it
Epsilon (let's leave it like that) is the energy level below the maximum fermi level.
So in order to minimize the Kinetic Energy the value of epsilon must be the largest??
h nu - phi - epsilon = 0 is the least fermi level
for aluminium since phi = 4.2 eV then
h nu - phi - epsilon = (4.14 x 10^-15 )(1.6x 10^-19) c / 160x10^-9 - 4.2 - epsilon = 0
a value of epsilon is found now
so epsion represents the integral difference from the maximum fermi level??
the epsilon i find out is the least kinetic energy that an electron can have asa result , yes?
I hope i actually ahve the correct answwer for the first part.
The second part is the number of photons per second.
Read my original post and please help with it!
Here, your calculated "epsilon" represents the DEEPEST level before the top Fermi level that the incoming photon can cause an electron to escape. I answered your question using this because you asked why there is a distribution of energy of the outgoing photoelectrons. I explain that a photon just doesn't excite only the electrons at the topmost Fermi energy state. It can also excite the electrons below that too. Whether these electrons can be excited enough that it will leave the metal depends entirely on the energy of the photon, the work function, and how deep below the Fermi level they are in. I did not realize you had to also calculate this energy level! I simply gave this as a qualitative explanation to make sure you do not hang on to this "partial photon" fallacy.
Epsilon is NOT a measure of the "cut-off" freq. The cut-off frequency is DEFINED as the smallest freq. of the incoming photon that will cause a photoelectron to be emitted. Look at your photoelectric effect equation! If you are given the work function, what is the smallest h*hu to give you the threashold for photoemission? This should be obvious.
Zz.
  • · Replies 35 ·
  • · Replies 25 ·
9K
