I want to make a DC adapter which outputs 13.5V 6AMP
  • Thread starter Thread starter alpstheguru
    Adapter Dc
The discussion revolves around the construction of a DC adapter that outputs 13.5V at 6A, specifically for use with a 240V AC input. Participants explore the necessary components, safety regulations, and potential alternatives available in the market.
  • Experimental/applied
  • One participant seeks advice on components such as transformers, diodes, and capacitors for building a specific DC adapter.
  • Another participant emphasizes the importance of adhering to safety regulations when working with AC mains voltages and suggests that the specified output may not be achievable with a transformer-based adapter.
  • A participant mentions having knowledge of safety regulations but expresses certainty about the availability of 240V AC mains in their location.
  • Another participant shares an example of a similar power supply that operates on 240V and outputs 13.5V at 5A, questioning the availability of such products in India.
  • There is curiosity about the implications of the difference between 5A and 6A outputs in the context of the project.
Participants express differing views on the feasibility of achieving the desired specifications with a transformer-based adapter, and there is no consensus on the availability of suitable products in India.
Participants mention safety regulations and the need for specific construction techniques when dealing with AC mains, but the discussion does not resolve the technical challenges associated with the design of the adapter.
alpstheguru
Any links or suggestions would be really helpful. I have a basic understanding about transformers, bridge rectifier & capacitor. I need help in shopping what transformer, diodes & capacitors should i buy. I tried to search online but couldn't find any. Adapter Specs IN> AC:100v-240v OUT> DC:13.5v 6AMP.
What I'm trying to make is
http://www.faylist.com/allliquidation/adapters/creative_ua1460_ac_adapter.htm
for 240V input instead 120V IN.
Thanks..
Thanks..
Welcome to the PF.
Can you tell us what safety regulations apply to the AC Mains side of the adapter? Are you going to build it to UL safety specs, or TUV, or some other agency's safety specs? Working with AC Mains voltages is dangerous, so it's important that you understand the construction techniques that are required at the input section for the switch and transformer.
Also, your specs, "IN> AC:100v-240v OUT> DC:13.5v 6AMP" are not achievable with a transformer-based adapter. You would need to make a switching regulator to accomplish those specs, and that involves even more design issues...
Well,
I have about safety regulations But I'm certain that AC mains gives out 240V. What I'm trying to make is one of these http://www.faylist.com/allliquidation/adapters/creative_ua1460_ac_adapter.htm
But this one takes 120 V input & its not available in India. I want to make one as i specified above.
Creatiive certainly sell similar power supplies that run on 240V. I've got one sitting next to my PC right now in the UK. Model Number TEAC 66-135000V. 230V in, 13.5V 5A out. It looks the same as your picture.
Your specification "IN> AC:100v-240" means it will work on either 120 or 240V mains.
I don't know if there are any issues about them being unavailable in India, though.
Cool Thanks. I wonder how much difference would 1 amp make. I'll try to find if it is available here.
  • · Replies 31 ·
10K
  • · Replies 39 ·
