Number of points on the plane vs. number of points on the line
  • Context: Graduate
  • Thread starter Thread starter Helicobacter
    Line Plane Points
The discussion revolves around the cardinality of the set of points in R^2 compared to R, exploring whether they are equal or if one is greater than the other. Participants delve into concepts of bijections, isomorphisms, and the implications of cardinality in different mathematical contexts, including additive groups and vector spaces.
  • Some participants question whether the cardinality of R^2 is greater than that of R, noting that R^2 is a superset of R.
  • Others argue that R and R^2 have equal cardinality due to the existence of a bijective function between them, suggesting that cardinality is a specific measure that does not depend on intuitive notions of "size."
  • A participant points out that cardinality can yield counterintuitive results, such as the bijection between the integers and the even integers.
  • Some participants propose that the set of real numbers is isomorphic to the set of complex numbers under certain conditions, specifically as additive groups.
  • There is discussion about the implications of the axiom of choice in proving isomorphisms between R and C as vector spaces.
  • Concerns are raised about the nature of bijections and the need for careful definitions when discussing cardinality and group properties.
  • Participants explore the use of specific functions, such as the tangent function, to demonstrate cardinality between intervals and the whole set of reals.
  • Some participants express curiosity about the nature of addition in different contexts and how it affects the isomorphism between sets.
Participants express a mix of agreement and disagreement regarding the cardinality of R and R^2, as well as the isomorphism between R and C. While some points are clarified, the discussion remains unresolved on several aspects, particularly concerning the implications of different addition operations and the nature of bijections.
Participants note that the proof of isomorphism between R and C as additive groups requires a different approach than proving cardinality, and that some proofs may be non-constructive, relying on the axiom of choice. The discussion highlights the complexity of defining operations and the conditions under which certain properties hold.
Helicobacter
Is the number of points/cardinality in R^2 greater than R, or are they equal?
if they are equal, how does one explain the following: R^2 is a superset of R, it has infinitely many R's...
Cardinality is a specific measure of the "size" of a set which only deals with the equivalence relation that is: two sets A and B have equal cardinality if there is a bijective function from A to B. In this context R and R^2 have equal size, because we can find such a bijection. In fact, A and A^2 will generally have the same cardinality for infinite sets A.
That R^2 may seem "bigger" in a different context doesn't matter when it comes to cardinality. In another sense this is true: if you consider R as the x-axis of R^2, R will have lebesgue-measure 0 while R^2 will have infinite lebesgue measure. Both are useful ways of interpreting size, but it's important to keep the two concepts separate.
Wait: there's a bijection between the integers and the even integers, even though the big one has TWO copies (evens and odds) of the small one. Cardinality does these strange things.
but this should imply that the set of REALS is isomorphic To the set of complex
since ther would always be a biyection between a real number 'x' and a complex number a+bi
Here's a bijection. We can, without loss of generality, assume that the real numbers are in the interval [0, 1].
Write the real number x in its decimal form, as x = 0.d1d2d3d4d5d6...
Form the complex number z = 0.d1d3d5... + 0.d2d4d6... i
This is basically the same way that R can be mapped one-to-one to R2.
And, the reals are indeed isomorphic to the complex numbers as additive groups! They're not isomorphic as fields however...
Under what 'addition'?
The usual addition. The point is that [tex]\mathbb{R}[/tex] and [tex]\mathbb{C}[/tex] are [tex]\mathbb{Q}[/tex]-vector spaces of thesame dimension. Thus the two spaces are isomorphic as vector spaces, but this exactly means that the additive groups are isomorphic.
This of course uses the axiom of choice...
I'm also curious about Jarle's question. For example, one way to prove that the interval (-pi/2, pi/2) has the same cardinality as the whole R, is to use the bijection f(x) = tan(x). But, since tan(x+y) is not in general equal to tan(x) + tan(y), more work appears to be needed in order to prove that these sets are isomorphic.
Well, obviously R and (-pi/2,pi/2) cannot be isomorphic as groups since (-pi/2,pi/2) isn't even a group... But R and (-pi/2,pi/2) do have the same number of elements though (= the same cardinality). To prove that two sets have the same cardinality, it suffices to find a bijection between them, you don't care whether the group property is satisfied.
It is easily seen that R and C have the same cardinality. Mark supplied a nice proof of this. All I said was that they are also isomorphic as groups, but this requires a different proof then what Mark supplied. In fact, the proof is a little harder, since it is nonconstructive (= it requires the axiom of choice!).
Hi, MM,
(-pi/2, pi/2) is not a group... under the usual addition. But it can be a group under the addition operator '*', defined as x*y = arctan(tan(x) + tan(y)). Hence Jarle's question (and mine).
Now, if you say the proof is non-constructive, then there's no point on asking what the addition operation is... but man... curiosity itches...
Of course you can always repeat the trick, and say that, if there exists a bijection between R and C, call it g:R -> C, and if you define the operation '@' defined as x@y = g^-1(g(x) + g(y)), then (R,@) is isomorphic to (C,+). But again, that was not the assertion of that non-constructive proof.
Dodo said:
Hi, MM,
Oops, sorry if my answer was not clear. But the addition is the usual addition. Thus
in R: a+b is just the usual addition.
in C: (a+bi)+(c+di)=(a+c)+(b+d)i is again the usual addition.
That's the point, that we are dealing with the usual additions. Not some "exotic" addition like arctan(tan(x)+tan(y)). The nonconstructive part comes in actually defining the isomorphism between the two groups.
OK... I was just curious about that proof. I'll try to google harder. :)
I agree, nifty solution. In general we require that the dimensions are of equal cardinality, which clearly is satisfied here. The isomorphism function would be tricky to find, it is impossible to write it down.
  • · Replies 16 ·
  • · Replies 36 ·
