Carnot engine ( Thermodynamics )
The discussion centers on calculating the mechanical power required for an air conditioner operating as a Carnot engine, given outside and inside temperatures of 32°C and 21°C, respectively, and a heat leakage of 9000 kcal/hr. The calculated efficiency of the Carnot engine is 0.03607, leading to a work requirement of 290 kW, which contradicts the expected answer of 36 kW. Participants clarify that the efficiency should be interpreted as the Coefficient of Performance (COP) for a Carnot refrigerator, prompting a reevaluation of the calculations using the correct formulas.
  • Carnot engine efficiency calculations
  • Understanding of Coefficient of Performance (COP)
  • Thermodynamic temperature conversions (Celsius to Kelvin)
  • Heat transfer principles in thermodynamics
  • Learn about the Coefficient of Performance (COP) for refrigeration cycles
  • Study the Carnot cycle and its applications in thermodynamics
  • Explore heat transfer calculations and conversions between kcal and watts
  • Investigate common errors in thermodynamic problem-solving
Students and professionals in thermodynamics, HVAC engineers, and anyone involved in the design or analysis of refrigeration systems.
Zamze
8. A house is cooled by an air conditioner. The outside temperature is 32°C and the inside temperature is 21°C. The heat leakage into the house is 9000 kcal/hr. If the air conditioner has the efficiency of a Carnot engine, what is the mechanical power required to keep the inside temperature constant? Answer given to this problem is [36kW]
efficiency= 1 - Temperature cold/ Temperature hot for carnot engine in Kelvins.
Also efficiency=Temperature cold/ work done.
I believe this should be enough.
Using the first given equation.
Efficiency=1-(21+273)/(32+273)=0.03607
Using the second equation W=9000kcal/hr/0.03607
Converting properly 9000kcal/hr=9000*4.184*60^2 gives us the work
Thus W=9000*4.184/(0.03607*60^2)=290KW
Can anyone explain to me why I am not getting 36KW?
Thank you!
I'd have used [tex]K=\frac{|Q_C|}{W}=\frac{Ht}{Pt}=\frac{H}{P}[/tex]
Target variable is P
[tex]K=K_{\text{carnot}}=\frac{T_C}{T_H-T_C}[/tex]
[tex]P=\frac{H}{K}[/tex]
This doesn't seem to give the answer you're after though! Hopefully that has helped a little bit.
The heat removed is related to the work done by the Coefficient of Performance (COP):
[tex]COP = output/input = Q_c/W = Q_c/(Q_h-Q_c)[/tex]
For a Carnot refrigerator:
[tex]Q_c/(Q_h-Q_c) = T_c/(T_h-T_c)[/tex]
Determine the amount of heat removed in one unit of time (Qc) and plug that and the value for COP into the first equation above to determine the rate of work (hint: use one second as the unit of time - be careful about converting calories to watts).
Unless I am misunderstanding what the question is asking (I am interpreting the "efficiency" to mean the COP and the reference to "Carnot engine" as "Carnot refrigerator") the given answer is wrong.
AM
10K
