How Do You Solve a Second Order Differential Equation Using Laplace Transforms?
The discussion revolves around solving a second-order differential equation using Laplace transforms. The specific equation is \(\frac{d^{2}y}{dt^{2}}+4y=\sin(t)\) with initial conditions \(y(0)=0\) and \(\frac{dy}{dt}(0)=0\). Participants are exploring the application of Laplace transforms to this problem.
  • Mixed
  • Participants are attempting to apply the Laplace transform to the differential equation and are discussing the transformation of terms, particularly the term involving \(4y\). There are questions about the correctness of the transformations and the use of convolution in the solution process. Some participants are also questioning assumptions made in the setup of the problem.
The discussion includes various attempts to clarify the application of Laplace transforms, with some participants providing corrections to earlier statements about the transformations. There is an ongoing exploration of different approaches, including convolution and partial fraction decomposition, but no consensus has been reached on the correct method or interpretation of the problem.
Some participants note potential errors in the original poster's approach, including the presence of terms that may not belong in the problem. There is also mention of confusion regarding the signs in the Laplace transform of certain terms.
PiRho31416
[Solved] Laplace Transform
[tex]\frac{d^{2}y}{dt^{2}}+4y=sin(t),\quad y(0)=0,\quad\frac{dy}{dt}(0)=0[/tex]
Laplace transform is defined as:
[tex]\mathcal{L}\{f(t)\} = \int_{-\infty}^{\infty}f(t)e^{st}dt[/tex]
[tex] \frac{d^{2}y}{dt^{2}}+4y=sin(t),\quad y(0)=0,\quad\frac{dy}{dt}(0)=0[/tex]
[tex]s^{2}\mathcal{L}\{y\}-sy'(0)-y(0)-4\mathcal{L}\{y\}=\frac{1}{s^{2}+1}[/tex]
[tex]\mathcal{L}\{y\}(s^{2}-4)=\frac{1}{s^{2}+1}[/tex]
[tex]\Rightarrow \frac{1}{s^{2}+1}\cdot \frac{1}{s^{2}-4}=\frac{As+B}{s^2+1}\cdot\frac{Cs+D}{s^2-4}[/tex]
[tex]1 = (As+B)(s^2-4)\cdot(Cs+D)(s^2+1)[/tex]
[tex]1 = As^3-4As+Bs^2-4B+Cs^3+Cs+Ds^2+D[/tex]
[tex]1 = s^3(A+C)+s^2(B+D)+s(C-4A)+D-4B[/tex]
[tex]\begin{bmatrix}<br /> 1 & 0 & 1 & 0\\ <br /> 0 & 1 & 0 & 1\\ <br /> -4 & 0 & 1 & 0\\ <br /> 0 & -4 &0 & 1<br /> \end{bmatrix}<br /> \begin{bmatrix}<br /> A\\ <br /> B\\ <br /> C\\ <br /> D<br /> \end{bmatrix}<br /> =\begin{bmatrix}<br /> 0\\ <br /> 0\\ <br /> 1\\ <br /> 0<br /> \end{bmatrix}<br /> \\\<br /> \begin{bmatrix}<br /> A\\ <br /> B\\ <br /> C\\ <br /> D<br /> \end{bmatrix} =<br /> \begin{bmatrix}<br /> -1/5 \\<br /> 0 \\<br /> 1/5 \\<br /> 0<br /> \end{bmatrix}[/tex]
[tex]\mathcal{L}\{Y\}=\frac{1}{5}\frac{1}{s^2-1}-\frac{1}{5}\frac{1}{s^2+1}[/tex]
[tex]\Rightarrow\mathcal{L}\{\frac{1}{5}\frac{1}{s^2+1}\}=\frac{1}{5}sin(t)[/tex]
[tex]\Rightarrow\mathcal{L}\{\frac{-1}{5}\frac{1}{s^2-1}\}=\mathcal{L}\{\frac{-1}{5}\frac{1}{(s+1)(s-1)}\}[/tex]
So this is where I get stuck using convolution. Since we know
[tex]\Rightarrow \mathcal{L}^{-1}\{\frac{1}{s+1}\} = e^{-t}[/tex]
[tex]\Rightarrow \mathcal{L}^{-1}\{\frac{1}{s-1}\} = e^{t}[/tex]
[tex]f(t)=e^{t}[/tex]
[tex]g(t)=e^{t}[/tex]
[tex]f(t) \ast g(t) = \int_{0}^{t}f(\tau)g(\tau-t)\,\,d\tau[/tex]
[tex]\frac{1}{5}\int_{0}^{t}e^{-\tau}e^{\tau-t}\,\,d\tau<br /> = \frac{1}{5}\int_{0}^{t}e^{-\tau+\tau-t},\,\,d\tau<br /> = \frac{1}{5}\int_{0}^{t}e^{-t}\,\,d\tau \\<br /> =\frac{1}{5}\tau e^{-t} \bigg|_{\tau=0}^{\tau=t} = \frac{1}{5}te^{-t}[/tex]
[tex]f(\tau)=e^{-\tau}[/tex]
[tex]g(\tau-t)=e^{\tau-t][/tex]
Why not use 1/[(s+1)(s-1)] = (1/2)[1/(s-1) - 1/(s+1)]?
RGV
Uhm. The Laplace transform of +4y is not -4Y.
RGV
Thanks! Duh!
Pretty sure it is.
Pretty sure it's NOT!
If
[tex]\mathcal{L}(y)= \int_0^\infty e^{-st}y(t)dt[/tex]
then
[tex]\mathcal{L}(4y)= \int_0^\infty e^{-st}4y(t)dt= 4\int_0^\infty e^{-st}y(t)dt= 4\mathcal{L}(y)[/tex]
not [itex]-4\mathcal{L}(y)[/itex].
Oh crap. The negative sign! Sorry it was late last night and somehow I thought he was saying [tex]\mathcal{L}\{y(t)\}\neq Y[/tex]
Sorry about that. He even says it's +4y not -4y. Geez :-(
If
then
For what it's worth: the convolution of exp(t) and exp(-t) is sinh(t), not c*t*exp(-t) or c*t*exp(t). You made an error in your convolution integral.
RGV
The OP made several mistakes. There should be no 1/(s2-1) term in the problem in the first place.
