Solve Trig Derivative: -8\int sec^3(\theta)+2sec^2(\theta)+sec(\theta)d\theta
  • Context: Graduate
  • Thread starter Thread starter tangur
    Derivative Trig
The discussion revolves around the evaluation of the integral involving trigonometric functions, specifically focusing on the expression -8∫ sec³(θ) + 2sec²(θ) + sec(θ) dθ. Participants explore different approaches to solving the integral and clarify steps in the process.
  • Mathematical reasoning, Technical explanation, Debate/contested
  • One participant suggests completing the square for the integral and transforming it into a trigonometric form involving sec(θ).
  • Another participant claims to have found a constant of -4 related to the integral.
  • Concerns are raised about the positivity of the first integral and the implications of the sign on the radical in the second integral, with one participant arguing that the sign should remain under the square root.
  • Further clarification is provided regarding the handling of the radical, suggesting that the expression should be placed in parentheses to manage the negative sign correctly.
Participants express differing views on the treatment of the radical and the signs involved in the integrals, indicating that there is no consensus on the correct approach to the problem.
There are unresolved assumptions regarding the handling of the square root and the implications of sign changes in the integrals, which may affect the evaluation of the integral.
tangur
[tex]\int \frac {x^2}{\sqrt{4x-x^2}}dx[/tex]
I just want to be sure I'm right on this, complete the square first of all so you get [tex]-\int \frac {x^2}{\sqrt{(x-2)^2-4}}dx[/tex] let [tex]u=x-2[/tex] thus [tex]-\int \frac {(x+2)^2}{\sqrt{u^2-4}}dx[/tex]then let[tex]u=2sec(\theta)[/tex]
hence integral becomes [tex]-8\int sec^3(\theta)+2sec^2(\theta)+sec(\theta)d\theta[/tex]
and then solve.
Thanks
I got -4 as the constant
the first integral is always positive, the second one doesnt. You can't just invert the sign on the radical and take one minus out... the sign on the radical should stay, which, if you think about it, might make things easier
true, since its under a sqrt root, you keep it under, but you put the whole expression under square root in parenthesis and take out the minus one, and then go x^2-4x. makes sense
thx guys
