12 DC Volt Boost to 15 DC Volt - 1 amp
The discussion centers around the feasibility of boosting a 12V DC power supply to 15V DC to power Labtech speakers in an RV setup. Participants explore various methods to achieve this voltage increase, potential risks, and the operational characteristics of the speakers at different voltages.
  • One participant suggests adding 2 or 3 Duracell Rechargeable AA batteries in series to boost the voltage from 12V to 15V, questioning the longevity and replacement indicators for the AA batteries.
  • Another participant warns against this approach, indicating it could lead to dangerous outcomes like smoke and flames.
  • A different participant expresses skepticism about the need for the voltage boost, noting that many devices can operate on voltages slightly above or below their rated voltage, suggesting the speakers might work fine at 12V.
  • One participant shares personal experience running devices rated for lower voltages on higher voltages, advising caution regarding polarity to avoid damaging devices.
  • A suggestion is made to use an isolated DC-DC converter as a safer alternative to boost the voltage from 12V to 15V.
Participants do not reach a consensus; there are multiple competing views regarding the necessity and safety of boosting the voltage, with some advocating for trying the speakers at 12V and others suggesting a more cautious approach.
Participants express uncertainty about the operational limits of the speakers and the implications of running them at different voltages. There are also unresolved questions about the safety and reliability of using additional batteries for voltage boosting.
This discussion may be of interest to individuals looking to power audio equipment in RVs, those exploring battery configurations, and participants interested in safe electrical practices in DIY projects.
RV-Traveler
Superb Old Labtech Speakers to add to my RV without 120 Volt AC
The Labtech AC adapter's output is 15VDC 1000ma.
Using my existing 12VDC power supply (2 - 6VDC inline Deep charge Batteries)
may I boost this output to 15VDC by adding 2 ?or? 3 Duracell Rechargeable AA batteries.
Duracell posts these NiMH AA as 1.2V / 2450mAh.
These AA would be all inline and on the + line of the RV power.
Any possible problems I overlooked?
How do we estimate how long the AA will last or do we how do we know when the AA batteries need replacement?
N.B.: All batteries will be charged while driving with the 1000W Powerbright Inverter in my 2500D Silverado.
I would highly suggest not doing that. You might be adding smoke and flames along with your speakers.
Try the speakers at 12V and see how that works.
BoB
I would actually be surprised if it didn't run fine off of 12V. Many devices like this will operate on voltages that are slightly higher or lower than they're rated V. You may lose a little volume at max level, but I doubt it will be much. I am running a device that's supposed to take 5VDC and I'm running it from 12VDC. I don't recommend this, but it was a cheap enough device I figured I'd give it a shot.
I also have run a device rated at 12V on a 9V power supply without a problem. I would go ahead and give it a try, just make sure you get the polarity correct, I have seen devices get killed when the polarity is reversed...
For a one-off, I'd just get an Isolated DC-DC converter if this is a concern.
You could then take your 12V input to 15V safely and in a nice little package.
Something like this might work http://products.cui.com/CUI_PTK15-Q24-S15_Datasheet.pdf?fileID=1081
  • · Replies 50 ·
28K
