Faster than light theory #759309
The discussion revolves around the theoretical implications of a helicopter blade's motion and whether the outermost section could exceed the speed of light if the inner section were to approach light speed. The scope includes conceptual exploration and theoretical reasoning related to special relativity.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant proposes a scenario where the outer section of a helicopter blade could theoretically move faster than light if the inner section were to reach near-light speed, questioning the practical implications of such a scenario.
  • Another participant counters that no object can be absolutely rigid due to the principles of special relativity, suggesting that the outer blade's speed would still be limited relative to the inner section.
  • A further response emphasizes that even with a hypothetical rigid material, the energy required to achieve such speeds would be prohibitive, as energy would also be needed for the outer section indirectly.
Participants express disagreement regarding the feasibility of achieving speeds greater than light with the proposed scenario, with some asserting that it is impossible under the constraints of special relativity.
The discussion highlights limitations related to the assumptions of rigidity and energy requirements, as well as the dependence on the principles of special relativity.
malikah
faster than light theory #759309...
imagine a propeller from a helicopter...we know that the part of the blade farthest form the pivot point moves faster than the section nearest to the pivot point... so in theory, if we could get the section nearset to the pivot point to move close to the speed of light, then would the outer most section be moving at, or faster than the speed of light? (taking into consideration that we are using the strongest materials we have and it is well lubed etc etc...) I'm not sure what purpose this would serve other than to get ones picture on the front of a science mag... but n e way...
Science news on Phys.org
no object is absolutely rigid as a consequence of special relativity. From an outsider's point of view, the blade would still be moving at a speed even nearer to the speed of light, when compared to the speed of the "section nearest to the pivot point".
There is no such "strongest" material anymore.
Even if you theoretically consider a very rigid material, you cannot get the outer section to be moving at a speed greater than or equal to that of light.
Because in this case, the energy that you need to supply to the inner part would still exceed any amount of energy,since actually you are also providing energy to the outer part, if only indirectly.
ahh..good answer..sigh...
  • · Replies 40 ·
