How Much Work Did the Hamster Do on the Exercise Wheel?
  • Thread starter Thread starter Hughey85
    Rotational Work
The discussion focuses on calculating the work done by a hamster on an exercise wheel, specifically using the formula for rotational energy. The hamster achieves a speed of 0.8 m/s on a wheel with a radius of 0.10 m and a mass of 5.9 g. To determine the work done, participants emphasize the importance of comparing the rotational energy before and after the hamster starts running, utilizing the equation Erot = (1/2)Iω2. The moment of inertia and angular velocity are critical components in this calculation.
  • Understanding of rotational dynamics
  • Familiarity with the concept of moment of inertia
  • Knowledge of angular velocity
  • Basic grasp of energy conservation principles
  • Learn how to calculate moment of inertia for different shapes
  • Study angular velocity and its relationship to linear speed
  • Explore the concept of torque and its applications in rotational motion
  • Investigate energy conservation in rotational systems
Physics students, educators, and anyone interested in understanding the principles of rotational motion and energy calculations.
Hughey85
After getting a drink of water, a hamster jumps onto an exercise wheel for a run. A few seconds later the hamster is running in place with a speed of 0.8 m/s. Find the work done by the hamster to get the exercise wheel moving, assuming it is a hoop of radius 0.10 m and mass 5.9 g.
I'm not sure how to solve this one. I think you use
Work=(torque) x (delta theta)
Torque = rF
but, after that, I'm not sure what theta would be. Am I even using the right set of equations? Thanks for all the help! :smile:
All you need to do is compare the rotational energy before and after! That will equal the amount of work the hamster did. The rotational energy is half the product the moment of inertia and the square of the angular velocity.
Thanks to ehild for catching my missing 1/2!
Tide said:
All you need to do is compare the rotational energy before and after! That will equal the amount of work the hamster did. The rotational energy is the product the moment of inertia and the square of the angular velocity.
half of this...
[tex]E_{rot}=\frac{1}{2}I\omega^2[/tex]
ehild
12K
  • · Replies 64 ·
