Bhabha Scattering Cross Section Derivation
  • Thread starter Thread starter eoghan
    Scattering
The discussion focuses on deriving the Bhabha scattering cross section, specifically the differential cross section formula: \(\frac{d\sigma}{d\Omega}=\frac{e^4}{32\pi ^2 E^2_{cm}}\left[ \frac{1+cos^4\frac{\theta}{2}}{sin^4\frac{\theta}{2}}-\frac{2cos^4\frac{\theta}{2}}{sin^2\frac{\theta}{2}}+\frac{1+cos^2 \theta}{2}\right]\). The participants clarify that the coupling constant \(g\) should be defined as \(g=\frac{e^4 E^2_{cm}}{c^2}\) to align with physical dimensions, and they confirm that spin dependence introduces additional factors in the angular distribution. The discussion emphasizes the importance of accurately incorporating spin effects in the theoretical model.
  • Understanding of quantum field theory and Feynman diagrams
  • Familiarity with the concept of cross sections in particle physics
  • Knowledge of coupling constants and their dimensional analysis
  • Basic principles of angular dependence in scattering processes
  • Study the derivation of the Bhabha scattering cross section in detail
  • Learn about the role of spin in scattering processes in quantum field theory
  • Research the implications of coupling constants in particle interactions
  • Explore advanced topics in Feynman diagrams and their applications in particle physics
Particle physicists, students of quantum field theory, and researchers focusing on scattering processes and theoretical models in high-energy physics.
eoghan
Hi!
I'm trying to derive the cross section of the bhabha scattering:
[tex]\frac{d\sigma}{d\Omega}=\frac{e^4}{32\pi ^2 E^2_{cm}}\left[ \frac{1+cos^4\frac{\theta}{2}}{sin^4\frac{\theta}{2}}-\frac{2cos^4\frac{\theta}{2}}{sin^2\frac{\theta}{2}}+\frac{1+cos^2 \theta}{2}\right][/tex]
I'm using the "toy theory" where at each vertex of a feynman diagram I associate a factor -ig, for each internal line there corresponds a propagator 1/q^2. The formula I get is:
[tex]\frac{d\sigma}{d\Omega}=\frac{1}{64\pi ^2 E^2_{cm}}\left(\frac{g^2}{E^2_{cm}}\right)^2\left[ \frac{1}{sin^4\frac{\theta}{2}}-\frac{2}{sin^2\frac{\theta}{2}}+1\right][/tex]
Now, the incorrect angular dependence comes from the fact that in the toy theory I don't consider the spin, I guess. Looking at the correct formula I guess that the spin dependence gives a factor of
[tex]1+cos^2\theta[/tex]
to the annihilation diagram and a factor of
[tex]1+cos^2\frac{\theta}{2}[/tex]
to the exchange diagram.
Is it right?
Then there is the problem of the value of the coupling constant g. The text says that it can't just be "e" because in the toy theory g has the value of a momentum, while in the real world it is dimensionless. So, what is the value of g? It should be
[tex]e^4E^2_{cm}[/tex]
in order to get the right expression?
Yes, you are correct about the spin dependence giving the factors 1+cos^2θ for the annihilation diagram and 1+cos^2θ/2 for the exchange diagram.The value of g is indeed e^4 E^2_{cm}. This is because the momentum in the toy theory has the same dimension as the energy, so we need to convert the energy to a momentum by multiplying it with the speed of light c. Thus, the coupling constant is g=e^4 E^2_{cm}/c^2.
  • · Replies 22 ·
