Can I Calculate a Power Triangle with Given Voltage and Current?
  • Thread starter Thread starter AngusBurger
    Power Triangle
The discussion centers on calculating the three sides of a power triangle using a voltage of v=25sin(wt+0.2rads) and a current of i=15sin(wt-0.5rads). The user correctly calculates the apparent power as 375 Volt-Amps (VA) using the formula VRMS*IRMS. To find the true power, the average power formula Pav = VrmsIrmscosφ is utilized, where φ is the phase difference derived from the voltage and current waveforms. The need to calculate impedance is clarified as unnecessary for this specific calculation.
  • Understanding of AC circuit theory
  • Familiarity with phasor representation of voltage and current
  • Knowledge of power calculations in electrical engineering
  • Basic trigonometric identities and their application in electrical formulas
  • Study the concept of phase angle (φ) in AC circuits
  • Learn about the relationship between true power, apparent power, and reactive power
  • Explore the derivation and application of the average power formula Pav = VrmsIrmscosφ
  • Investigate the use of instantaneous power calculations in AC systems
Electrical engineers, students studying AC circuit analysis, and professionals involved in power system design and analysis will benefit from this discussion.
AngusBurger
This is an enquiry into whether something is possible, so the numbers might be rubbish to work with.
If I apply a voltage of v=25sin(wt+0.2rads) to a circuit, with a resultant current of i=15sin(wt-0.5rads), can I work out all three sides of a power triangle? I've been working on it for about an hour but with no such luck.
This is what I have done so far:
VRMS*IRMS = 25*15 = 375 Volt-Amps
So long as that is correct, my guess would be that I have to find the True Power, perhaps using the formula P=VIcosϕ, and then I can use Pythagorus theorem to find the volt-amps reactive (var), which would be with the formula var2=VA2-W2. If that's not right, I assume I would have to work backwards in order to calculate an impedance?
Any help with this would be much appreciated. I think that it is possible using only a source voltage and resultant current, but am obviously to new to the subject to properly hack it out.
Welcome to PF!
Hi AngusBurger! Welcome to PF! :smile:
(have an omega: ω :wink:)
The instantaneous power is P(t) = V(t)I(t).
If you multiply it out, and use a bit of trig, you find that P(t) = VrmsIrms(cosφ + cos2ωt). :wink:
(So the average power is Pav = VrmsIrmscosφ.)
You don't need to find the impedance for this.
  • · Replies 32 ·
  • · Replies 55 ·
9K
