Why Does My Range for a Composite Function Differ from the Textbook's?
The discussion revolves around determining the range of a composite function involving two defined functions, p(x) and q(x). The original poster, Peter G., presents a discrepancy between their calculated range and the range provided in a textbook.
  • Exploratory, Assumption checking
  • Peter G. attempts to find the range of the composite function (q∘p) and presents their result. Other participants question the definition of the function q(x) and explore the implications of using absolute values.
The discussion is ongoing, with participants providing feedback on the original poster's calculations and questioning the assumptions about the function definitions. There is no explicit consensus yet, but some guidance has been offered regarding the interpretation of the function q(x).
Participants are discussing the definitions of the functions and the implications of potential absolute values in the function q(x). The original poster's domain constraints for p(x) are also noted.
Peter G.
Function p and q are defined by:
p (x) = 3x2+1, x∈R, Domain 0≤x≤2
q (x) = x2 - 2, x∈R
(q∘p) - State the range:
I got -1 ≤ y ≤ 167
The book says 0 ≤ y ≤ 167
Any idea where I went wrong?
The composite function I got so then I could sub was:
9x4 + 6x2 - 1
Thanks,
Peter G.
Your answer looks good to me.
Are you sure q(x) is not |x2 - 2| ?
The notation exactly how it is in the book is the following:
q : x → x2-2, x∈R
Looks fine. |x2 - 2| was the simplest way I could see to get the book answer, so you appear to be correct: Range = [-1, 167] .
Cool :smile:
Thanks a lot SammyS
And, if you don't mind, what are those two vertical lines?
Absolute value .
  • · Replies 22 ·
  • · Replies 23 ·
