Gravity Turbine: Harnessing Power from Falling Mass
  • Context: Undergrad
  • Thread starter Thread starter Danille
    Gravity Turbine
The discussion centers on the concept of harnessing energy from gravity without the use of water, specifically through a gravity turbine. Participants clarify that while energy can be generated from moving water to turn turbines, it is impossible to extract useful energy solely from the gravitational field of the Earth. The conversation emphasizes the necessity of an energy input, such as solar energy, to facilitate processes like water evaporation and subsequent energy generation. Additionally, the distinction between kinetic energy and the energy required to operate turbines is highlighted, noting that turbines typically rely on heat and pressure rather than gravity alone.
  • Understanding of gravitational energy and its limitations
  • Knowledge of kinetic energy principles
  • Familiarity with turbine mechanics and energy conversion
  • Basic concepts of thermodynamics related to energy input and output
  • Research the principles of gravitational energy and its applications
  • Explore kinetic energy conversion methods in mechanical systems
  • Study the mechanics of turbines, including types and operational principles
  • Investigate thermodynamic cycles and their role in energy generation
Engineers, energy researchers, and anyone interested in renewable energy technologies and the principles of energy conversion.
Danille
We can make energy from the force of water moving, to turn a turbine. Is there a way to eliminate the water, but to just use the pull that gravity exerts against all matter instead?
If you need to have mass moving in order to harness that power, is there a way to siphon off the energy that is expended when things fall to the ground, even if it only a tiny amount of energy and then mutiply that process to an expotential rate?
Welcome to the PF.
There is no "free energy". For a water turbine to work, you need the energy input of the sun to evaporate water to return it to the top of the reservior in the form of rain. Unfortunately, you cannot tap useful energy out of the gravitational field of the Earth alone.
I think you may find there is a difference in turning a simple "wheel" using kinetic enegry
where the weight of the water or whatever material you use offsets the wheel causing it to turn. A turbine does use the same basic concept but instead of using simple kinetic enegry, heat is generally applied to burn fuel, create steam or pressure and that force is used to turn the device at controlled or acellerated speeds for whatever purpose. Using gravity goes back to a kineticly driven device like a wheel which is offset by wheight causing it to turn.
  • · Replies 74 ·
11K
  • · Replies 26 ·
10K
