| New Reply |
Ball attached to String (Potential Energy) |
Share Thread | Thread Tools |
| May14-11, 02:18 PM | #1 |
A 2.40 kg ball is attached to a ceiling by a 2.00 m long string. The height of the room is 3 m. What is the gravitational potential energy of the ball relative to: a) the ceiling? b) the floor? c) a point at the same elevation as the ball? Variables P for potential energy m for mass in kg g for gravity h for height 2. Relevant equations P=mgh 3. The attempt at a solution For b), I found the answer which was 23.52. For a), though, I got 70.56 because P=(2.4)(9.8)(3)=70.56. The 3 is from the fact that the ceiling is 3m off the ground and a) is asking about the ceiling. It says that I'm wrong For c), I don't have any idea of what they're talking about. Is it the same thing as b)? |
| May14-11, 02:53 PM | #2 |
Energy is always relative. Potential energy is defined as the potential energy of one point, vs. the potential energy at another point. The equation, more precisely, should be written [tex]U = mg \Delta h[/tex] for some different in height [tex]\Delta h \equiv h - h_0[/tex].
Usually the 'reference' point ([tex]h_0[/tex]) is taken to be "zero height" ([tex]h_0 = 0[/tex]), and that is often either sea-level, or ground-level, or floor-level, etc. |
| May14-11, 02:59 PM | #3 |
ok, so I did 2.4(9.8)(1)=23.52 for a). i still get it wrong....
and for c), do i just do 2.4(9.8)(2) because it's the inverse? |
| May14-11, 03:04 PM | #4 |
| May14-11, 03:16 PM | #5 |
| May14-11, 03:18 PM | #6 |
so will a) be negative because 2-3=-1? therefore, will the answer be -23.52?
and will c) be zero because 2-2=0 and 2.4(9.8)(0)=0? |
| May14-11, 03:23 PM | #7 |
@vespa71
the problem said the ceiling to the floor was 3m |
| May14-11, 03:24 PM | #8 |
a) will be negative becaus there's a 2!! meter negative drop from the ball to the ceiling. c) is zero as there's no drop. Well done.
| May14-11, 03:33 PM | #9 |
I recommend to make a simple drawing to visualize the problem. Best of luck
| May14-11, 03:35 PM | #10 |
well ok, i did 2.4(9.8)(-1). that gives me -23.52. it still tells me i'm wrong
| May14-11, 03:37 PM | #11 |
oh and thanks for c). i got it right.
| May14-11, 03:51 PM | #12 |
If you have a -2m drop from ball to ceiling, and a 1m drop from ball to floor, and a 0m drop from ball to somthing on the same level, I think it will solve.
| New Reply |
| Thread Tools | |
Similar Threads for: Ball attached to String (Potential Energy)
| Ball twirling on string attached to stick | Introductory Physics Homework | 11 | ||
| Potential Energy! (A box attached to a spring which is attached to the ceiling.) | Introductory Physics Homework | 13 | ||
| Calculating the tension attached to a ball attached to coaster rolling down incline | Advanced Physics Homework | 0 | ||
| Roller coaster, ball attached to coaster by a string... calculate various tension | Advanced Physics Homework | 0 | ||
| a ping-pong ball attached to a string in a jar of water | Introductory Physics Homework | 2 | ||
