Arghhh Coordinate geometry question
The discussion revolves around a coordinate geometry problem involving a square defined by points A and C. The original poster seeks to find the coordinates of points B and D, as well as the area of the square, based on the given vertices.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest calculating the slope and length of diagonal AC, using the midpoint to derive the slopes of the other diagonal, and employing equations to find points B and D. Questions arise regarding the application of these equations to determine the coordinates of B and D.
Some participants have provided guidance on using the midpoint and slopes to formulate equations, while others are exploring different methods, such as using circle equations to find intersection points. There is an ongoing exploration of various approaches without a clear consensus on the best method.
The problem is not part of assigned homework, but it has been a source of frustration for the original poster and their classmates, indicating a shared interest in resolving the question despite time constraints in class.
ultraviolent
Hi everyone. This is a question that was attempted in class but no on (including our teacher) could solve in the time we had left. It's not actually homework, but it's really getting on my nerves!
The quadrilateral ABCD, where A is (4,5) and C is (3, -2), is a square. Find the coordinates of B and D and the area of the square.
Many thanks,
- James
You can find the slope of line segment AC (a diagonal) as well as its length and its midpoint. The negative reciprocal of that slope is the slope of the other diagonal since you're working with a square. Write an equation of a straight line using the point-slope form using the midpoint and the slope of the second diagonal. Use that equation to find the two points on that line that are half the length of the diagonal from the midpoint. That gives you the points B & D.
Knowing the length of the diagonal you can easily find the area of a square.
I already managed to do the first part, but how would you use the equation derived from this to calculate the points half the length of the diagonal from the midpoint?
let the equation to be the first equation.
find another circle equation that its center is at the midpoint of AC and the radius of half the length of AC. The circle will pass all the corner points of the square. solve the two equations will give the points of intersection of the circle and the straight line which will give point B and D.
(0,2) & (7,1).
  • · Replies 16 ·
