Cutting 6mm Dia Glassfiber Disks - Tips & Ideas
  • Thread starter Thread starter beho86
    Machining
The discussion revolves around methods for cutting 6 mm diameter disks from a composite material made of layered glassfiber, with a thickness of 3-4 mm. Participants explore various cutting techniques, tools, and their effectiveness in achieving accurate and refined edges.
  • One participant inquires about the best, accurate, and affordable way to cut glassfiber disks, mentioning previous unsuccessful attempts with a punch and a hollow cutter.
  • Another suggests that plastics and reinforced materials can be machined similarly to metals using lathes and mills.
  • A CNC mill is proposed as a potential solution, although concerns about material waste are raised.
  • A wood plug cutter is recommended as a viable option, with notes on its affordability and effectiveness when used in a drill press.
  • Participants discuss the importance of a rigid setup for using the plug cutter and suggest alternative methods like hand sanding after an oversize cut.
  • One participant questions whether disks would get stuck in the plug cutter and expresses concerns about material waste compared to milling.
  • Abrasion water jet cutting is mentioned as a method that could provide the best surface finish, though cost is a concern for some participants.
  • Another participant suggests using a jigsaw if precision is not critical.
  • Ultimately, one participant reports success with the wood plug cutter after trying it.
Participants express a range of opinions on the best cutting method, with no consensus on a single approach. Various techniques are debated, and while some participants find success with the plug cutter, others remain concerned about material waste and precision.
Participants mention the thickness of the composite material and the need for refined edges, but specific tolerances are not detailed. The discussion includes various assumptions about the effectiveness of different tools and methods without resolving these uncertainties.
Individuals working with composite materials, particularly those involved in cutting and shaping glassfiber or similar materials, may find the insights and suggestions relevant.
beho86
Hello,
I am working on a project, and I need to cut ~ 6 mm dia disks, and 3~4 mm thickness. The material is a composite made out of layered glassfiber. I am cutting those samples out of a 5 x 5 in composite.
My question is what is the best, accurate, and affordable way to cut those samples?
I tried to use a punch through the panel, but it gave me a destroyed disk. I have a custom made hallow cutter to cut the disks, but the tip bended with only 2 ~3 samples prepared.
I was thinking about using a hole saw, but I couldn't find a 1/4 in dia cutter, as I need the disks to have well refined edges. Any tips or ideas?
Most plastics including reinforced materials are commonly machined just like metals on lathes, mills, etc... This is a lathe cut part.
so, probably the only way is to use a CNC mill, but it is going to waste a lot of materials. Thanks for the suggestion Q_Goest
You might try a wood plug cutter. These work in a drill press and are used to cut round plugs from a board. 1/4 in. is a common size. Fiberglass can usually be worked with wood cutting tools. Plug cutters are cheap, so give it a try.
Yeah, the wood plug sounds good, as long as your setup is very rigid. I'm assuming you won't have a center drill because you want an entire disc, so you'll have to find a way to mount the plug cutter.
Also don't underestimate making an oversize cut by hand and then sanding it to the desired radius. It will take a little finesse, but it is the cheapest way, and if it meets your tolerances/specs, there's no reason not too.
Lastly, a cnc mill will give you the best results, and you could potentially lose the least amount of material depending on what end-of mill you use.
What is the thickness of th 5*5 sheet you have and what are your tolerances?
Plug cutters mount in a standard drill press chuck, same as a drill. They do not have a center hole, although some have a centering pin, which I think retracts as you drill. Once you've run the plug cutter, you cut the plug free from the block with a saw (band saws work good for this, also hand saws). Cut the plug a little longer than needed and then sand to final length.
You can buy one at Home Depot or Loews, shouldn't need to go to a high end or specialty store.
I was thinking about using plug cutters, but It will probably waste the same amount if I were to mill the disk using 1/8 end mill. don't the disk gets stuck inside the plug cutter?
I will try to use the cnc mill tomorrow and see.
The thickness of the 5 x 5 in blocks is about 4 mm. refining the disk by hand will take a lot of time, as I will be cutting more than 50 disk. Thanks guys
For that material, abrasive water jet will give you the best surface finish.
Is this FR4 or a similar material? If so the best option is to used a carbide (or better) tool at high speed.
Actually, the very best option is to use a water jet like stated above.
Water jet will be expensive for my work. It's similar to FR4, but it has several layers. I will be trying a plug cutter tomorrow, and I hope it works. it should be probably the fastest.
You could try using a jigsaw if you don't need the cuts to be very precise.
Thanks a lot guys. I used a wood plug cutter, and it worked like a charm. thx
  • · Replies 42 ·
  • · Replies 16 ·
