Physics Help : gravitational field
The discussion focuses on calculating the angular speed (ω) of two stars with masses 1020 kg and 2 × 1020 kg, rotating about their common center of mass. The gravitational constant (G) is given as 6.7 × 10-11 Nm2/kg2, and the distance between the stars is 106 km (converted to 109 m). Using the formula for centripetal force and Newton's Law of Universal Gravitation, the calculated angular speed is 2.11 rad/s.
  • Understanding of Newton's Law of Universal Gravitation
  • Familiarity with centripetal force concepts
  • Knowledge of angular motion and angular speed
  • Ability to perform unit conversions (km to m)
  • Study the derivation of the center of mass for two-body systems
  • Learn about gravitational interactions in multi-body systems
  • Explore advanced topics in rotational dynamics
  • Investigate the implications of angular momentum conservation
Astronomy students, astrophysicists, and anyone interested in celestial mechanics and gravitational interactions between stars.
alamin
Two stars, masses 10^20kg and 2* 10^20kg respectively, rotate about their common centre of mass with an angular speed of w. Assuming that the only force on a star is the mutual gravitational force between then, calculate w.
Distance = 10^6km and that G= 6.7*10^-11Nm^2/kg^2
Find out the location of center of mass. Let it be [tex]r[/tex] away from one of the stars.
Then use
[tex]\frac{G \mu m}{r^2} = mr \omega^2[/tex]
where r is the reduced mass of the two stars.
[tex]\mu=\frac{Mm}{M+m}[/tex]
spacetime
www.geocities.com/physics_all/index.html
To calculate the angular speed, we can use the formula for the centripetal force: Fc = mw^2r, where Fc is the centripetal force, m is the mass of the star, w is the angular speed, and r is the distance between the two stars.
First, we need to find the distance between the two stars in meters, since G is given in SI units. Converting 10^6km to meters, we get 10^9m.
Next, we can calculate the force of gravity between the two stars using Newton's Law of Universal Gravitation: Fg = (Gm1m2)/r^2, where Fg is the force of gravity, G is the gravitational constant, m1 and m2 are the masses of the two stars, and r is the distance between them.
Plugging in the values, we get:
Fg = (6.7*10^-11Nm^2/kg^2)(10^20kg)(2*10^20kg)/(10^9m)^2
= 1.34*10^30N
Since the only force acting on the stars is the force of gravity, this must also be the centripetal force, so we can set Fc equal to Fg and solve for w:
Fc = Fg = mw^2r
1.34*10^30N = (10^20kg + 2*10^20kg)w^2(10^9m)
1.34*10^21 = 3*10^20kgw^2
w^2 = (1.34*10^21)/(3*10^20kg)
w^2 = 4.47
w = √4.47
w = 2.11 rad/s
Therefore, the angular speed of the stars rotating around their common center of mass is 2.11 rad/s.
  • · Replies 23 ·
  • · Replies 16 ·
