How Do You Calculate E(XY) for Dependent Variables with Given Observations?
  • Context: Undergrad
  • Thread starter Thread starter James1990
    Expectation
The discussion revolves around calculating the expected value E(XY) for two dependent random variables X and Y, given a specific number of observations and the sum of their products. The scope includes theoretical reasoning and mathematical approaches to expectation in the context of dependent variables.
  • Technical explanation, Debate/contested, Mathematical reasoning
  • One participant seeks assistance in calculating E(XY) given that X and Y are dependent random variables, with a specific sum of their products and number of observations.
  • Another participant suggests estimating E(Z) where Z=XY using the formula E(Z) = Sum(XY)/n, which they calculate as 1060.84/21.
  • A third participant states that expectation does not require independence, proposing that E(XY) can be calculated as E(X)*E(Y) or Sum(XY)/n, but notes that this may be misleading due to the dependency of X and Y.
  • This same participant emphasizes that E(XY) may not equal E(X)E(Y) if X and Y are dependent, and points out that the lack of specific information about X and Y makes E(X) and E(Y) irrelevant in this context.
Participants express differing views on the calculation of E(XY) for dependent variables, with some suggesting methods that assume independence while others caution against this assumption. The discussion remains unresolved regarding the best approach to take.
There are limitations regarding the assumptions made about the distributions of X and Y, as well as the implications of their dependency on the calculation of expectation.
James1990
Hi everyone,
I was searching an answer for E(XY), where X and Y are two dependent random variables, number of observations n=21 and Sum(x*y)= 1060.84. Can somebody help me?
It's not mentioned, but I think that each x and y of the distributions have the same probability to occur.
Thank you.
Since you don't know anything about X and Y individually, you could think in terms of Z=XY. Then the estimate for E(Z) = 1064.84/21.
Expectation doesn't require independence so you can just do E(xy)=E(x)*E(y) or in this case, sum(XY)/n
This statement is misleading, E(XY) may not = E(X)E(Y) if they are dependent. However in the problem stated here, nothing in particular is known about X and Y, only the product, so E(X) and E(Y) are irrelevant.
  • · Replies 30 ·
  • · Replies 43 ·
