What is the Magnetic Field Between Parallel Plate Electrodes?
The magnetic field between two parallel plate electrodes carrying a current J is described by the formula B_z (y,z)=\frac{\mu J}{2\pi d}(\vartheta_1+\vartheta_2). This formula derives from the magnetic field generated by a single plate, represented as B_z (y,z)=\frac{\mu J}{2\pi d}\vartheta. The discussion highlights the challenge of applying Maxwell's equations to derive this result and clarifies that \vartheta is a TeX command representing the lowercase Greek letter theta.
  • Understanding of Maxwell's equations
  • Familiarity with electromagnetic theory
  • Knowledge of TeX typesetting for mathematical notation
  • Basic principles of current flow in conductors
  • Research the derivation of magnetic fields from current-carrying conductors
  • Study the application of Maxwell's equations in electromagnetic fields
  • Explore the use of TeX for writing complex mathematical expressions
  • Investigate the properties of magnetic fields in parallel plate configurations
Students and professionals in physics, electrical engineering, and anyone studying electromagnetic fields and their applications in parallel plate systems.
airbuzz
I have two parallel plate electrodes in which flows a determined current J. I found that the magnetic field between the two electrodes is:
[tex]B_z (y,z)=\frac{\mu J}{2\pi d}(\vartheta_1+\vartheta_2}[/tex]
(see attached figure)
This comes form the field generated by a plate that is:
[tex]B_z (y,z)=\frac{\mu J}{2\pi d}\vartheta[/tex]
Does anybody knows from where come this formula and how to demonstrate it??
I´m just fighting against Maxwell´s equations, but they are winning...
Can you explain [tex]\vartheta[\tex] means?[/tex]
it is a TeX command to write theta in that way.
\theta [tex]\Rightarrow\,\,\theta[/tex]
\vartheta [tex]\Rightarrow\,\,\vartheta[/tex]
  • · Replies 16 ·
