New Reply
Angular Velocity, Momentum, and Kinetic Energy
Share Thread Thread Tools
May16-11, 01:52 AM   #1
1. A merry go round (1000kg) initially at rest with a diameter of 4m is pushed with a tangential force of 500N for 10s. Find the angular velocity, angular momentum, and rotational kinetic energy. After this, a little girl (mass - 1 kg) is placed on the rim of the merry go round.. Calculate the final rKE, final angular velocity, and what fraction of the initial rotational KE is lost as heat.
2. I used-
s = r x theta
F = ma
v = d/t
a = v/t
c = pi x d
angular velocity (w) = theta / t
angular momentum (L) = Inertia / w
rKE = 1/2 I w^2
3. By using the basic kinematic equations I got that d = 50m, and then calculated that to be 25 radians. I found theta to be 12.5 radians, and then using the equations found w = 1.25 radians/sec, L = 2500 Nxmxs, and KE = 1562.5 J.
For part B, it says to assume the little girl is a point mass- I am assuming she will decrease the acceleration because she increases the mass... but then I'm still missing time variables. HELP!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May16-11, 02:29 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi xobeckynoel! welcome to pf!
(have a theta: θ and an omega: ω and try using the X2 icon just above the Reply box )
Quote by xobeckynoel View Post
it's difficult to check your work unless you show your full calculations
i think you're misinterpreting the question …
the force (and the acceleration) has stopped before the girl gets on …
the merry-go-round has constant angular velocity both before and after she gets on, and you need to use conservation of angular momentum (momentum and angular momentum are always conserved if there is no relevant external force or torque )
New Reply
Thread Tools
Similar Threads for: Angular Velocity, Momentum, and Kinetic Energy
Thread Forum Replies
Angular Momentum and Angular kinetic energy about the center of the sun. Introductory Physics Homework 1
orbital angular momentum and kinetic energy Advanced Physics Homework 3
angular momentum/kinetic energy Introductory Physics Homework 1
Kinetic energy and Angular momentum Introductory Physics Homework 10
Angular Velocity and Kinetic Energy Problem? Introductory Physics Homework 12
