| New Reply |
Continuity, given topologies. |
Share Thread | Thread Tools |
| May16-11, 02:01 AM | #1 |
Is the function f: R -> R, x -> x^2 continuous when the domain and codomain are given the Half interval topology? (Or Lower Limit topology).
I'm not sure where to go with this. On inspection, I know that the intervals are open sets, so preservance of open sets in preimages are defined for x > 0. But what if there is a set [x^2,x^2+r) that is in the negative part of the real line, there is no pre-image for this set. Is there something I'm missing, or just not realizing (most likely the second one)? |
| May16-11, 02:37 AM | #2 |
| May16-11, 04:41 AM | #3 |
It was only by inspection, assuming that any sets in the negative real line for this particular function don't have pre-images in the real line. If that assumption is wrong, then I've got nothing to go on to prove it's not continuous, so it must be, but that's a very weak justification.
| May16-11, 09:10 AM | #4 |
Hi Slats18
![]() Can you tell me what [tex]f^{-1}([x,x+r[)[/tex] is? |
| May27-11, 06:42 AM | #5 |
Sorry for the really late reply, been busy with other topological concerns, namely product topologies haha.
I'm completely blanking on this at the moment, no matter how interesting topology is, it just doesn't stick. Would it be [sqrt(x),sqrt(x) + r) ? |
| May27-11, 11:44 AM | #6 |
Not exactly. You'll need to figure out what f-1(x) and f-1(x+r) are (there are multiple values). Then you need to figure out what happens to the points between x and x+r...
| May29-11, 01:53 AM | #7 |
On further, concentrated inspection, given [x,x+r) the pre-image of this is
( -(sqrt(x+r)),-(sqrt(x)) ]U[ sqrt(x),sqrt(x+r) ) which isn't open as -sqrt(x) is an element of the pre-image, but there is no r > 0 such that [-sqrt(x),r) is an element of the pre-image as well. |
| May29-11, 08:45 AM | #8 |
Looks right to me!!
| May29-11, 06:42 PM | #9 |
Could it be also said, not neccessarily proven, that because the mapping is from R to R, the pre-image is not defined for certain R and hence, not continuous?
Ex: Take the interval [-1,0). The preimage of this is obviously in the complex plane, hence not in R. |
| May29-11, 06:48 PM | #10 |
[tex]f^{-1}([-1,0[)=\emptyset[/tex] |
| May29-11, 07:16 PM | #11 |
Ohh, duh, of course haha. My mistake, I'm doing topology and complex analysis so sometimes the two subjects mix haha.
| New Reply |
| Thread Tools | |
Similar Threads for: Continuity, given topologies.
| Weak topologies | General Math | 0 | ||
| How many different topologies can X have? | Differential Geometry | 4 | ||
| sample topologies | Differential Geometry | 1 | ||
| different induced topologies | Calculus | 6 | ||
| More about finer topologies | Calculus & Beyond Homework | 7 | ||
