What Is the Acceleration of Two Blocks in a Frictional System?
  • Thread starter Thread starter natalydj83
    Acceleration
The acceleration of two blocks in a frictional system, where a 1 kg block on a tabletop is connected by a string to a 2 kg hanging block, is calculated to be approximately 7.5 m/s². The coefficient of kinetic friction is 0.3, and the normal force acting on the first block is 9.8 N. The correct equation for tension in the string is derived from the forces acting on both blocks, leading to the conclusion that the initial calculation of 7.51 m/s² is accurate, confirming the solution provided by the user.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of kinetic friction and its calculation (Friction = μ * Normal Force)
  • Familiarity with free-body diagrams for analyzing forces
  • Basic algebra for solving equations involving multiple variables
  • Study the effects of varying coefficients of friction on acceleration in similar systems
  • Learn about tension in strings and its role in connected mass systems
  • Explore the implications of frictionless pulleys in mechanical systems
  • Investigate more complex systems involving multiple blocks and pulleys
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of frictional systems and acceleration calculations.
natalydj83
hw Problem:
A block of mass 1 kg rests on a tabletop with coeficient of kinetic frictionequal to 0.3. The block is conected by a string which passes over a frictionless pulley to a second block of mass 2kg which hangs vertically from the string. The acceleration of the two block is...?
mass(1)=1kg
mass(2)=2kg
uk=0.3(coeficient)
Fr(friction)=uk*Fn(normal force)
My solution:
(x)F=ma
box 1
component (x)=Ft(force tension)-Ffr(friction)=ma
component (y)=Fn(normal force)-mg(weight)=m(a=0)
Fn=mg
Fn=1kg*9.8=9.8N
component (x)=Ft-uk*Fn=ma
component (x)=Ft=ma-uk*Fn
Ft=ma-0.3*9.8=ma-2.94
Ft1=ma-2.94N
Box 2
component (y)=mg-Ft=ma
mg-ma=Ft
Now: Ft1=Ft2
m(1)a-2.94=m(2)g-m(2)a
a=(m(2)g+2.94)/m1+m2
a=(2*(9.8)+2.94)/2+1=7.51m/s^2
IS THIS SOLUTION RIGHT? If not please indicate where i made a mistake
On box 1 you made a mistake, Ft-uk*Fn=ma then you went to Ft=ma-uk*Fn. It should be Ft=ma+uk*Fn.
natalydj83 said:
hw Problem:
mass(1)=1kg
mass(2)=2kg
uk=0.3(coeficient)
My solution:
(x)F=ma
box 1
Fn=mg
Fn=1kg*9.8=9.8N
Ft1=ma-2.94N
Box 2
mg-ma=Ft
Now: Ft1=Ft2
The net force is F=2*9.8+0.3*9.8=22.54 N. The net mass is m=2+1=3kg. So the acceleration is a=F/m = 22.54/3=7.5 m/s^2. Thus your answer is correct
  • · Replies 21 ·
  • · Replies 27 ·
