New Reply
Material Science Questions....
Share Thread Thread Tools
May17-11, 01:15 AM   #1
Recognitions:
Gold Membership Gold Member
I finally got to exercise a bit of material science. I'd like to know whether what I'm saying correct or no. I also ran into two issues with Brinell's hardness calculations and SEA chart. I'd appreciate feedback! :)
1) Decreasing the size of the nucleus causes...
A) Increasing plasticity
B) Increasing strength
C) Thermic durability
D) A+B
I chose A. I do know for sure that decreasing the size of the nucelous makes the material stronger. It just makes more sense that when you have more little things to break
2) What's the correct sentence? (Based on the unit cell crsytal formation lattice)
A) Vanadium is more plastic than Magnesium
B) Vanadium is stronger than Magnesium
C) Vanadium is less hard than Magnesium in high temp'
Vanadium is a BCC. Mg is CPH.
CPH (and FCC) are denser than BCC. Therefor, I chooose B. Vanadium is stronger than Magnesium.
3) What thermal treatment is designed to unite steel?
A) Annealing
B) Homogenization
C) Tempering
I choose B. That's what I believe the manual is getting it.
4) What's the precentage of steel SAE10150?
A) 0.15%
B) 1.5%
C) 15%
I couldn't find a SEA chart in my book, so I looked at wiki, but wiki's list only starts from 201!
Does anyone have a good link for me for a chart?
5) In a normalization process the cooling is done:
A) In oil
B) In air
C) In an oven
"Air" form what I was able to google (also couln't find that in my book)
6) Calculate the hardness level by Brinell’s method
A) Ball diameter – 10mm
B) Dent size – 4mm
C) Pressing Force – 3000 [N
From some reason am getting syntax error!
Uploaded with ImageShack.us
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May17-11, 08:46 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by Femme_physics View Post
D) A+B
Assuming "nucleus" means grain... Why choose A if you "know for sure" that B is correct?
May17-11, 12:17 PM   #3
Recognitions:
4) What's the precentage ?carbon? of steel SAE10150?
A) 0.15%
B) 1.5%
C) 15%
SAE10XX are plain carbon steels. The percentage carbon is xx/100. For example SAE 1020 would be a low carbon steel (0.2%). SAE1060 would be fairly high carbon steel, 0.6% carbon. SAE10150 would have to be 1.5% carbon, a very high carbon steel.
See : http://en.wikipedia.org/wiki/SAE_steel_grades
May17-11, 01:17 PM   #4
Mentor
Quote by Femme_physics;33062996) Calculate the hardness level by Brinell’s method
B) Dent size – 4mm
[URL=http://imageshack.us/photo/my-images/839/synerror.jpg/
[/URL]
What software is giving you the syntax error? I see two things that might be causing a syntax error:
1) The dot in the denominator. Maybe you need to use *, which is commonly used for multiplication.
2) The expression 10(10 - <other stuff>). Possibly whatever you're using requires an operator (e.g., *) for multiplication.
May17-11, 02:31 PM   #5
Recognitions:
Quote by uart View Post
I see how it works, the "xx" represent the percentage then? So simple :)
Must've been a terrible mishap, was meant to be B :)
This is just a Microsoft Equation representation of what I plugged to my calculator.
I'll try it again tomorrow then and get back to you :) thanks.
May17-11, 05:32 PM   #6
Mentor
Re the syntax error. It looks like you have the right parenthesis in the wrong place in the denominator, part of which is shown below.
[tex]10(10 - \sqrt{10^2 - 4^2)}[/tex]
This should be
[tex]10(10 - \sqrt{10^2 - 4^2})[/tex]
IOW, the right paren should be outside the radical. That would definitely cause a syntax error.
May18-11, 03:25 AM   #7
Recognitions:
B) Dent size – 4mm
Be careful of units, are you sure Pressing Force is given in Newtons?
Other than that, your calculator ought to handle this expression.
You might add extra parentheses, to insure correct order of operations.
May18-11, 07:08 AM   #8
Recognitions:
Thanks you two :) Mark had it right on the money, it's about the right paren being outside of the radical. Many thanks over this :)
New Reply
Thread Tools
Similar Threads for: Material Science Questions....
Thread Forum Replies
Material Science Materials & Chemical Engineering 1
Examination-Style Questions. Density of Material Questions (b)(i)(ii) Advanced Physics Homework 5
what to do with a PhD in material science? Career Guidance 8
Material Science, Material Selection Question Engineering, Comp Sci, & Technology Homework 1
Material science Atomic, Solid State, Comp. Physics 10
