How Can Friction Impact the Movement of a Chain Off a Table?
  • Thread starter Thread starter gaborfk
    Kinetic Potential
The discussion focuses on the dynamics of a uniform chain of length 8.00m on a table, specifically addressing the conditions under which it begins to slide off and the calculation of its speed as it leaves the table. It is established that with a coefficient of static friction of 0.600, at least 3.00m of the chain must hang over the edge for sliding to commence. For part b, the kinetic friction coefficient is 0.400, and the solution involves calculating initial potential energy and work done against friction to determine the chain's speed as it exits the table.
  • Understanding of potential energy (U = mgh)
  • Knowledge of kinetic energy (K = 1/2mv^2)
  • Familiarity with friction concepts, specifically static and kinetic friction
  • Ability to apply energy conservation principles in physics
  • Calculate the work done against friction using W = Fd
  • Explore the relationship between linear density and mass for the chain
  • Learn about energy conservation in dynamic systems
  • Investigate the effects of varying coefficients of friction on motion
Physics students, educators, and anyone interested in mechanics, particularly in understanding the principles of energy conservation and friction in dynamic systems.
gaborfk
A uniform chain of length 8.00m initially lies stretched out on a horizontal table.
a) If the coefficient of static friction between the chain and the table is 0.600, show that the chain will begin to slide off the table if at least 3.00m of it hangs over the edge of the table.
b)
Determine the speed of the chain as all of it leaves the table, given that the coefficient of the kinetic friction between the chain and the table is 0.400.
I have solved part a no problem. Part b I am having a lot of problems with. I am trying to fill in the equation U(init)+K(init)-W(fric)=U(final)+K(final)
I understand that the right side is U(final) is 0 and K(final) is 1/2mv^2. How about the left side?
Thank you in advance
Don't you have a thread started on this same problem already?
https://www.physicsforums.com/showthread.php?t=48928
Here are some hints. If U(final) is zero, where are you measuring PE from? Use that same point to measure the initial PE from. Doesn't the chain start falling from rest? Figure out the work done against friction.
for any help!
For part b, the left side of the equation represents the initial potential and kinetic energy of the chain, while the right side represents the final kinetic energy of the chain as it leaves the table.
To solve for the initial potential and kinetic energy, we need to first calculate the height of the chain that is still on the table. We know that the total length of the chain is 8.00m and at least 3.00m of it hangs over the edge of the table, leaving 5.00m of the chain still on the table.
Using the formula for potential energy, U=mgh, we can calculate the potential energy of the 5.00m of chain on the table. The mass of the chain can be calculated using its linear density (mass per unit length) and the length of the chain on the table.
Next, we need to calculate the initial kinetic energy of the chain. Since the chain is initially at rest on the table, its initial kinetic energy is 0.
Now, we can plug these values into the left side of the equation:
U(init)+K(init)-W(fric) = mgh + 0 - W(fric)
The work done by friction, W(fric), can be calculated using the formula W = Fd, where F is the force of friction and d is the distance over which the force is applied. In this case, the force of friction is equal to the coefficient of kinetic friction (0.400) multiplied by the weight of the chain (mg) and the distance over which it acts is the length of the chain (8.00m).
Once you have calculated the work done by friction, you can plug it back into the equation and solve for the initial kinetic energy. Once you have the initial kinetic energy, you can solve for the speed using the formula K(final) = 1/2mv^2.
Hope this helps!
17K
15K
