Fusing: Interrupting 100A @ 1VAC vs. 600VAC
  • Thread starter Thread starter david90
The discussion revolves around the ability of a fuse rated at 100A @ 600VAC to interrupt a fault at 100A @ 1VAC. Participants explore the implications of voltage ratings on fuse operation, particularly in relation to heat generation and the conditions under which a fuse will blow.
  • Some participants assert that the 600VAC rating indicates the maximum voltage at which the fuse can operate correctly under fault conditions.
  • Others question whether a lower voltage (1VAC) would prevent the fuse from blowing, suggesting that heat generation is dependent on the voltage across the fuse element.
  • One participant clarifies that the voltage drop across the fuse is what matters for heat generation, not the supply voltage.
  • A participant raises a question about why a fuse rated at 100A @ 600VAC would blow at 100A with a line voltage of 240V, suggesting that the heat developed should be less in this scenario.
  • Another participant acknowledges a misunderstanding regarding the relationship between line voltage and the fuse's resistance, noting that the fuse element has a fixed resistance value.
  • One participant explains that when a fuse is blown, its resistance becomes infinite, which is crucial for preventing arcing and potential welding of the fuse.
  • There is a discussion about the implications of using a 1V circuit, including the need for lower load resistance and thicker cables due to the fuse's resistance.
Participants express differing views on the relationship between voltage ratings and fuse operation, particularly regarding the conditions under which a fuse will blow. The discussion remains unresolved with multiple competing perspectives presented.
Participants reference the geometry of the fuse and its resistance characteristics, but there are unresolved assumptions about how these factors interact with different voltage levels. The implications of using different line voltages and the resulting heat generation are also not fully clarified.
david90
If a fuse is rated @ 100Amp @ 600VAC, will it able to interrupt a fault @ 100Amp @ 1VAC (hypothetical value)? From my understanding, the 600VAC rating on a fuse is the maximum voltage that a fuse can burn out correclty under a fault condition. If the voltage is too low, won't that cause the fuse element not to burn up since heat = V * I?
Correct. The voltage rating of the fuse is dependent only on its geometry, and is an indicator of what voltage can be applied across the fuse after it opens, and you still won't get an arc-over:
http://en.wikipedia.org/wiki/Electrical_fuse
You are right that "Heat is VI" but the V, in the case of a fuse, is the voltage drop across the fuse and not the supply volts.
I guess my question is not clear :).
My question is why does a fuse with rating 100A @ 600VAC still blow @ 100A with a line voltage of 240V (or does it?) ?
The heat that develops across the fuse element with 100A @ 600VAC should be greater than 100A @ 240VAC. If so, then the fuse in the latter scenario should not blow since the fuse element feels less heat.
ops nevermind. Brain fart. The fuse element has a fixed resistance value so 100A across it will develop the same voltage drop regardless of line voltage.
The voltage rating is the amount the fuse can handle when open.
When the fuse is good, it's resistance is very low, so the voltage dropped should be very low.
When it's blown, it's resistance is infinite, and it is blocking the current. It has to withstand all of the supply voltage. If the voltage is too high, you might get arcing across it, and it might even weld itself closed. That is obviously a very bad thing.
Yes.
Although, of course, when you propose a 1V circuit, you would need a slightly lower load resistance for 100A to flow if a fuse were inserted in the circuit because the fuse resistance is finite. Actually, tin has a resistivity at least 10 times that of copper and a fuse tends to be quite thin so the fuse resistance could be higher than the connecting cable. Certainly, a 1V circuit would have to use pretty thick cables!:smile: 230V is a much cheaper system to implement.
11K
