| New Reply |
No conservation of momentum with bouncing ball? |
Share Thread | Thread Tools |
| May17-11, 08:36 PM | #1 |
So I was thinking about the conservation of momentum. If you throw a handball at a wall, the wall will provide an equal normal force, thus sending the handball back at the same velocity (in a perfect scenario). The ball has a momentum vector, the wall never moves, and thus only has a zero-amplitude vector. But in this closed system, the net momentum vector changes! How?
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| May17-11, 10:02 PM | #2 |
Mentor
The ball is not perfectly elastic: some of the spring energy in the bounce is converted to heat.
| May17-11, 10:04 PM | #3 |
| May17-11, 10:13 PM | #4 |
Mentor
It would bounce back with an equal momentum to what it started with.
| May17-11, 10:36 PM | #5 |
Sound is also a form of energy in which the initial energy of the ball gets converted to, so it loses energy there. In a perfectly elastic system the momentum is conserved completely and none is wasted. meaning p = p' (momentum before = momentum after)
| May17-11, 10:37 PM | #6 |
| May17-11, 10:39 PM | #7 |
| May17-11, 10:49 PM | #8 |
Thanks |
| May18-11, 05:41 AM | #9 |
Don't forget that when you threw the ball, the conservation law also applied and the Earth rotated backwards a tiny bit.
The amount it moves forwards would be twice that value for a perfectly elastic collision and an equal value for a totally inelastic collision. All the Mv's add up to zero in every case. |
| New Reply |
| Thread Tools | |
Similar Threads for: No conservation of momentum with bouncing ball?
| Biomechanics with dissipation and conservation of momentum of ball travelling upwards | General Physics | 4 | ||
| Conservation of momentum between a moving ball and a stationary ball? | Introductory Physics Homework | 1 | ||
| Bouncing ball HWK help | Introductory Physics Homework | 2 | ||
| Bouncing Ball KE and momentum?? | Introductory Physics Homework | 0 | ||
| Bouncing ball and momentum | Introductory Physics Homework | 5 | ||
