Shielding from electric/magnetic field using a metal box
The discussion revolves around the effectiveness of using metal boxes or spheres, specifically Faraday cages, for shielding against electric and magnetic fields. Participants explore the concepts of electromagnetic shielding, attenuation, and the limitations of different shielding methods, including anechoic chambers.
  • Some participants assert that a Faraday cage can shield electric fields and electromagnetic (EM) fields, but it cannot completely block them.
  • Others clarify that while a Faraday cage provides significant attenuation, it is not equivalent to complete shielding, which is only achievable with an anechoic chamber.
  • A participant notes that an anechoic chamber absorbs radiation to prevent reflections, distinguishing it from a Faraday cage, which prevents external EM radiation from entering.
  • There is a discussion about the limitations of Faraday cages in protecting against low-frequency magnetic fields, indicating that they may not be effective against inductive pick-up.
  • One participant suggests that superconductive cages could provide ideal shielding, while another counters that the shielding efficiency of superconductors varies with frequency, and mu-metal may perform better at high frequencies.
  • It is mentioned that effective shielding across all frequencies may require a combination of different materials, including mu-metal, superconductors, and regular conductors.
Participants express differing views on the effectiveness of Faraday cages and anechoic chambers, with no consensus reached on the completeness of shielding provided by these methods. The discussion remains unresolved regarding the best materials and methods for effective electromagnetic shielding.
Participants highlight the frequency dependence of shielding materials and the need for a combination of materials to achieve effective shielding across a range of frequencies. There is also mention of advancements in active RF cancellation technology.
manivas
Can electric fields can be completely shielded using a metal box or metal sphere,
please clarify the concept.
Yes. The name of the concept is Faraday cage.
A faraday cage can give huge attenuation but it can't completely block an EM field it is by definition a shield effect.
The only way to completely block a signal is a anechoic chamber (http://en.wikipedia.org/wiki/Anechoic_chamber)
Look in the RF section.
The walls of an anechoic chamber absorb any radiation produced inside the chamber, so that measurements are not confused by reflections (echoes) from the walls
A Faraday cage stops radiation EM produced outside from getting inside.
These are two different issues. An anechoic chamber for EM radiation would normally be built inside a Faraday cage, as the Wiki link said.
Yes, a Faraday cage will shield electric fields and EM fields. However, it won't protect you from inductive pick-up, i.e. it won't help against low-frequency magnetic fields (from say the mains).
Correct f95 and the better the conductivity the better the faraday cage. I guess a superconductive cage would give ideal shielding.
Most if not all RF anechoic chambers these days are for EMC testing and they are active suppression the same as noise cancellation headphones. If a signal is detected in the setup phase in the area of interest it will be actively canceled whether it is from inside or outside the wiki link is WAY WAY out of date. The cancellation will be to the sensitivity required for the compliance test.
I should say active RF cancelation has got so cheap and integrated that mobile phones are even carrying them on the antena to improve reception (http://www.intersil.com/signalintegrity/NoiseCancellingICs.asp)
Unfortunately not, the shielding efficiency of superconductors is frequency dependent. It gets worse as the frequency increases and mu-metal shields are actually better for screening magnetic fields at high frequencies.
Hence, the only way to make a shield that works well at all frequencies is to combine different types of materials (mu-metal, superconductors and good normal conductors).
